  4. Musings from the shop
fukinitupagianftwlikeabossifitaintbrokefi
136 Posts 22 Posters 2.6k Views 1 Watching
    The bolt pattern is the same but they're a little wider. If i switch to vented rotors I think they'll bolt right up. Otherwise I may have change the spacer between the two halves. I'm confident that they can be made to work without too much work.
    I've heard that they're used as an upgrade for air-cooled 911s too, so I feel lucky to have picked them up for a reasonable price.
      CYoung said:
      What isn't light weight on a Italian car
      The driver...
        Now I feel the urge to watch italian spiderman :
          I was trying to think of a clever comment for this one, but I got nothing.
            Jake farting at my new wheels.
              Full size Chevy ftw! I don't think I got a picture of it but the last E28 shell I scrapped was hauled on a uhaul 6x12 utility trailer with the tailgate down because it was 14 ft long. I also dragged the shell out of my garage on frame with the burb.
              Edit found the pic! Luckily with the snow I was able to rotate the shell by myself and then winch it on the trailer. Which leads me to the question on how you lifted the shell into the truck bed? Haha
              post-2724-0-41944400-1425235677thumb.jp
                I was surprised, the empty shell of a car is actually pretty light. Three of us lifted the front up by hand, and then used the engine hoist to lift the back up and pushed it in. Sounds simple, but it was a bit of work. I think it took about an hour start to finish.
                  Quoting these two pictures to carry the epicness on to page 4...
                    Good to know about the uhaul trailer. That may be how I haul my e36 shell for moving.
                    Sent from my potato phone
                      Ha, putting that e30 into a truck bed was one of the funnier things that I have done with a car.
                      E21 looks mint on those wheels.
                        Why is the shell being scrapped?
                          That was Mike's car that met the guard rail
                            Aside from the damage to the fender, core support and quarter panel, it was also pushed in maybe an inch at the B pillar. Also needed an engine, gas tanks, rear subframe/suspension refresh, the diff had a little bit of growl... I wish I could have done something with it, but I just don't have the time or the money right now and don't have anywhere to store it long-term.
                            The upside is that I can focus on the e21 now. Before Ben stopped at the shop with a z71 and a crazy idea to shove an e30 shell in the bed, I was working on getting the subframe cleaned up and removed the part where the drivers side motor mount was. The m42 motor mounts are farther back, so I have to weld new pads onto the subframe where they come down. Also dropped the suspension and started cleaning, cleaning, cleaning....
                              I pulled a sting to see how straight the driveline was going to be. It's attached to the diff flange in the rear, and I used the height of the output flange of the transmission to set the height of the string at the front of the car.
                              I put a pipe across the frame rails so that I'd have something to measure off of after I put the engine and trans in.
                              Whoa... that's not good. The front of the engine about an inch and a half low. Not a huge angle, but enough that I think I'm going to make a new transmission crossmember to compensate.
                              After I was happy with everything I welded up the crossmember and bolted it up to my mock-up engine. It's been a long time since I did any welding, but it turned out pretty good.
                              I was going to work on mounting the center support bearing today, but I forgot to order the the little dust shield that goes on the driveshaft, so I put some candy-colored bushings in my LCAs instead.
                                Had to take a picture of this, because... you know... cutting an oil-pan with a hacksaw. It felt wrong, and yet awesome at the same time.
                                Just making a little room for the steering rack.
                                  The cut is finished nicely, works for me.
                                  When do you think it will be driving?
                                    Ah... hard to say. Still have some work to do in the bay before I can paint it. The block is still at the machine shop waiting for pistons. Hopefully they will come this week. Then reassemble the engine, put it in the car, wiring, exhaust, fuel pump and lines, 10 other things that I forgot about and will probably have to wait on parts for.... hopefully early May? Late May is probably more realistic though.
                                      This thing is rad as phuck.
                                      Mike's swap by Jake Spence Photography, on Flickr
                                        Nice!
                                        I've been in a bit of a lull lately. Took me a few tries to get the center support bearing mounts for the e30 driveshaft done right. I finally got my pistons and dropped them off at the machine shop. Hopefully I'll have the block back by next weekend. It's been a long time since I made any visible progress, so I decided to put the front suspension back together and put the car back on the ground.
                                        I wheeled it outside and rinsed a couple months worth of accumulated dust off of it and now I'm totally stoked about getting it back on the road again. Spent a few hours today scrubbing down the engine bay. Will probably put some paint on it this week.
                                        This is what I like to see. A small forest of unused jackstands!
