Musings from the shop
I believe they're the same, but I haven't really looked into it yet. I've heard of people buying 24v turbo manifolds and chopping them down.
At the moment I'm leaning towards a NA build, but I haven't even gotten the block to the machine shop or dropped the subframe yet so it's a long way off.
Induction noise is a beautiful thing:
You're going to machine those? Looks like a difficult part. Damn kids and your fancy computerized equipment!
Just kidding. Honestly though I have some kind of pathologically masochistic DIY-or-die complex. I'll probably just go after a piece of flat stock with a hacksaw, some big drill bits and a file.
Honestly man, I guarantee you could learn how to draw that up, and machine it within a weekend. No one taught me how to draw 3d, so I just mess around with it at work until, well, something works.
The shop is in Green Lake, if you are ever interested in checking it out, or building your own parts, I have keys to the place and can come here 24/7. Only 1 shift 7-330.
Transition piece is much short. So I think around 2" alum billet flange for the transition is what I need. And go to larger tubing.
Port has a perimeter around 6" and 1.75 ID is 5.5 about so I need larger runners. 2" ID will get me ~6.3" which is just slightly larger(which is assume is what I want)
Dammit I need to go to school for engineering already.....
That's cool. I'm from Menasha, so you're not that far from me. I might have to take you up on that some time.
I wouldn't necessarily assume that the you need to keep the tube the same size as the port, but it's probably not a bad idea to do it that way. To do it right though, you have to look at the area of the opening, not the perimeter, as well as the length of the runner from the valve to the end of the tube.
The engineering concept that you're looking for is called "Helmholtz resonance". The wikipedia entry does a good job explaining it. The mass of the air in the runner causes it to have inertia, and the atmosphere outside the tube essentially acts like a spring. Putting some mass on a spring gives you a resonator. Changing the diameter or length of the runner changes the mass of the air inside and tunes the resonator to a different frequency (rpm).
The bolt pattern is the same but they're a little wider. If i switch to vented rotors I think they'll bolt right up. Otherwise I may have change the spacer between the two halves. I'm confident that they can be made to work without too much work.
I've heard that they're used as an upgrade for air-cooled 911s too, so I feel lucky to have picked them up for a reasonable price.
What isn't light weight on a Italian car
The driver...
Full size Chevy ftw! I don't think I got a picture of it but the last E28 shell I scrapped was hauled on a uhaul 6x12 utility trailer with the tailgate down because it was 14 ft long. I also dragged the shell out of my garage on frame with the burb.
Edit found the pic! Luckily with the snow I was able to rotate the shell by myself and then winch it on the trailer. Which leads me to the question on how you lifted the shell into the truck bed? Haha
I was surprised, the empty shell of a car is actually pretty light. Three of us lifted the front up by hand, and then used the engine hoist to lift the back up and pushed it in. Sounds simple, but it was a bit of work. I think it took about an hour start to finish.
I was trying to think of a clever comment for this one, but I got nothing.
Jake farting at my new wheels.
Quoting these two pictures to carry the epicness on to page 4...
Ha, putting that e30 into a truck bed was one of the funnier things that I have done with a car.
E21 looks mint on those wheels. -
That was Mike's car that met the guard rail
