  4. It's like the Same but Different: My 528e build
147 Posts 19 Posters 3.3k Views 2 Watching
    Same thing when car is off.
      Will it shift between the gears without the shifter linkage connected?
        If you want to purchase the G260 that is in my car now for cheaps, you are free to take it for a test drive on Saturday. I also have an eta bellhousing if you need
          I tried playing arouns with this a little but before putting things back together but didnt seem like i felt a difference.
            You should be able to shift gears by putting a screwdriver or something through the hole for the shifter linkage and rotate/push/pull (that's what she said) into all of the gears.
              Probably won't be out to the shop for 2 weekw but ill give that a try.
                Still working out the transmission issue but good news is I finally picked up the parts Mkoepp and AndyHundley had been holding for me! Clean front end panels and a new clutch set up. Also it seems whenever I go on a parts run I come back with another car... I'll post up E30 pics this weekend.
                  I didnt think you would ever get an E30. Glad to see you are piloting a bmw again
                    It's not for me! I wouldn't wanna stoop down from the higher ranks of elite 5er ownership. Jk it's a great car being reminded of what driving a M20 is like along with the body panels should get me in high gear for getting the E28 rolling in spring. As long as I can get me a trans 😕
                      Nothing like driving an M20 in an e30 to motivate you to drive something else... (#SHOTSFIRED)
                        Holy dumb stuff.
                        Ive had one heck of a day and then this guy happened^^
                        m20s are like family to me
                          Hahaha that was much quicker than I thought!
                            Oh go clean the carbon off your valves
                              Front end was taken apart last night. Kinda funny how the 15" wheels make accessing the inner fender body screws that much harder haha. If I had 16's on the car I would have had to swap them out working on the ground in the shop.
                              Anyways I'm gonna bend out the core support for now but its eventually need to be replaced if the car ever gets painted. Its torn up on the bottom from a previous accident and in general the whole support is bent inward slightly. I have rust holes on both of the footwells going into the wheel well. This should probably be fixed before everything gets rotted out.
                                So your rust free shell isn't rust free anymore?
                                  No sir.
                                    patch it with fiberglass, and make a jon boat
                                      Clutch line, slave and master cylinders ordered and I think I have a lead on a low mileage G260. I got spring fever for driving this.
                                        You and me both, sir! Keep up the great work.
                                          S/O to Mike the hippest MF'er for picking up a trans for me at Schmidts/Don's in Hortonville. Little crusty at 205k but should do the job.
                                          post-2724-0-10318600-1426636754thumb.jp
