  4. It's like the Same but Different: My 528e build
145 Posts 18 Posters 0 Views 1 Watching
    I didnt think you would ever get an E30. Glad to see you are piloting a bmw again
      It's not for me! I wouldn't wanna stoop down from the higher ranks of elite 5er ownership. Jk it's a great car being reminded of what driving a M20 is like along with the body panels should get me in high gear for getting the E28 rolling in spring. As long as I can get me a trans 😕
        Nothing like driving an M20 in an e30 to motivate you to drive something else... (#SHOTSFIRED)
          Holy dumb stuff.
          Ive had one heck of a day and then this guy happened^^
          m20s are like family to me
            Hahaha that was much quicker than I thought!
              Oh go clean the carbon off your valves
                Front end was taken apart last night. Kinda funny how the 15" wheels make accessing the inner fender body screws that much harder haha. If I had 16's on the car I would have had to swap them out working on the ground in the shop.
                Anyways I'm gonna bend out the core support for now but its eventually need to be replaced if the car ever gets painted. Its torn up on the bottom from a previous accident and in general the whole support is bent inward slightly. I have rust holes on both of the footwells going into the wheel well. This should probably be fixed before everything gets rotted out.
                  So your rust free shell isn't rust free anymore?
                    No sir.
                      patch it with fiberglass, and make a jon boat
                        Clutch line, slave and master cylinders ordered and I think I have a lead on a low mileage G260. I got spring fever for driving this.
                          You and me both, sir! Keep up the great work.
                            S/O to Mike the hippest MF'er for picking up a trans for me at Schmidts/Don's in Hortonville. Little crusty at 205k but should do the job.
                            post-2724-0-10318600-1426636754thumb.jp
                              So we didn't get as far as we wanted today, the old trans is still in. I'm currently caught up on the top starter bolt that goes through the bell housing which is the only thing keeping the trans on the motor 😕 I ended up giving up on it for the night but came close to accessing the bolt with a wobble extension. Just a quick update for tonight as I need to head to bed. Pics for progress but the shop kinda exploded haha.
                              post-2724-0-96002600-1427081663thumb.jp
                                Is that a red neon?
                                  Yours should be through bolts with nuts to the starter right?  Use a 3/8" box end wrench over the torx head with the engine at the normal height and use a ratchet with extension to turn the nut on the starter side.  The wrench will turn until it hits the bell housing or firewall and stop allowing you to loosen the nut.
                                    Maybe that's my issue. I used all the old hardware when I swapped the trans from my last 528e into this car. The starter bolts through the bell housing are 17mm and the nut above the starter on the other side is a 15mm. I'll check the parts diagrams and see what it's supposed to be.
                                    @Earl yes that's my roommates bandit stock 4cyl prepped neon. Its finally ready to race this spring so I'll technically be part of a nascar pit crew haha
                                      Can you reach it from the engine bay if you lift the trans as high as possible in the tunnel?  I have never removed starter bolts from underneath.
                                        I can get the 17mm with a box wrench. The issue is the 15mm. I'll have to take a picture explain next time I'm at the shop. I thing if I buy a long handle flex head ratchet along with the wobble extension I should be able to break it.
                                          So the old trans is out! Bought a Gearwrench 120XP long handle flex head watched to use in combination with the extension and snap-on wobble ext to get that 15mm around to the nut. Ryan "Speizo" held the 17mm wrench on the other end and it came off! We dropped the trans afterwords and he pulled the clutch while I started on swapping the output flanges.
                                          I upgraded to the bigger SETA driveshaft long ago when the driveshaft went out on the old burgundrot since I had one from my first car. Made a thin wall 30mm and got the flange nut off fine from the old trans but I ended up stripping the one on the new trans 😕 Fortunately I've been through this before since the same thing happened when I did that swap originally. It was harder to brace the flange since the new trans still had the vibration dampener on so I get to cut through all of that next time.
