  4. It's like the Same but Different: My 528e build
147 Posts 19 Posters 3.3k Views 2 Watching
  • RamRod E28R
    RamRod E28R
    RamRod E28
    The 'burb will get jealous that it won't be going to meets anymore.... :D
    That burb is sweet tho! plus it has a WiBimmers sticker on it what more could you ask for???
    1988 BMW 528e - Need parts?
    1996 Mazda Miata (SOLD!!!)
    1996 BMW 325i (Donor car)
      Quick update, photos will come later. Got the shifter linkage rebuilt just need to reinstall, should make quite the difference. If i can get it into other gears then I'll have the car back together hopefully getting some sleep too.
        I better see this in two days!
        • BMWbenB
          BMWbenB
          BMWben
          Young family is finally getting all their shitty bmws rolling
          BMWCCA #499464
            Scratch that last comment, Still only grabs 4th gear. :(
            1. Trans is somehow bad?
            2. Shot clutch only grabs 4th?
            3. My mock shifter plate rear support isnt at the right height/angle.
              NOOOOOOOOOO!!!!
                Will it shift between gears with the engine off?  Or are the results the same?  If the clutch is not disengaging all of the way you will be able to shift with the car off but not with it running.
                  Same thing when car is off.
                    Will it shift between the gears without the shifter linkage connected?
                      If you want to purchase the G260 that is in my car now for cheaps, you are free to take it for a test drive on Saturday. I also have an eta bellhousing if you need
                        I tried playing arouns with this a little but before putting things back together but didnt seem like i felt a difference.
                          You should be able to shift gears by putting a screwdriver or something through the hole for the shifter linkage and rotate/push/pull (that's what she said) into all of the gears.
                            Probably won't be out to the shop for 2 weekw but ill give that a try.
                              Still working out the transmission issue but good news is I finally picked up the parts Mkoepp and AndyHundley had been holding for me! Clean front end panels and a new clutch set up. Also it seems whenever I go on a parts run I come back with another car... I'll post up E30 pics this weekend.
                                I didnt think you would ever get an E30. Glad to see you are piloting a bmw again
                                  It's not for me! I wouldn't wanna stoop down from the higher ranks of elite 5er ownership. Jk it's a great car being reminded of what driving a M20 is like along with the body panels should get me in high gear for getting the E28 rolling in spring. As long as I can get me a trans 😕
                                    Nothing like driving an M20 in an e30 to motivate you to drive something else... (#SHOTSFIRED)
                                      Holy dumb stuff.
                                      Ive had one heck of a day and then this guy happened^^
                                      m20s are like family to me
                                        Hahaha that was much quicker than I thought!
                                          Oh go clean the carbon off your valves
