  4. Doormans e30 325e
Doormans e30 325e
115 Posts 14 Posters 0 Views 1 Watching
    Doorman
    Ordered a new shift boot and ebrake boot from Nine Stitch in New York, he's also gonna give me a price on making a new houndstooth cover for my drivers seat. He expects it to be in the $300 range.
    Picked up a Harbor Freight 6" DA polisher. The DA gets some pretty good reviews from the detail guys online.
    Stopped at an Auto Body shop today on a recommendation from a mechanic next door (was fixing his door....hence "doorman"). Turns out the guy is into old BMWs!! Showed him pics of my hood/trunk and he said if I can't fix them wet sanding/polishing he'd paint them both for $500.
    Still scouring CL and checking around the forums for some 4x100 rims.
    Should be ordering suspension parts early February.
      It's always interesting who you find that is into BMW's, there are some quite unexpected ones.
        Doorman
        Busted out the Harbor Freight DA!!
        Did a test panel on the hood.
        Looked good so I started to go at the drivers side for a bit.
        7e622a3e14a5f403efc2bc7eaac883da.jpgdce1763be6180bca2072ee44ef15539c.jpgf6b5ff2f9d2d350139e2fbbbbf8454e7.jpg
        Don't know how well it's showing up in the pictures but in person it's nice!!
        Yellow pad
        Meg's ultimate compound
        Speed 4
        I may have to wet sand a bit on the leading edge.
          Nice results, it is amazing what a little work can bring out in some old paint.
          • M
            M
            michael1972
            What is a harbour freight DA exactly? My e30's paint is definetly in need of some TLC.
              Doorman
              http://m.harborfreight.com/6-in-57-amp-heavy-duty-dual-action-variable-speed-polisher-69924.html?utm_referrer=direct%2Fnot%20provided
                Doorman
                Some more detailing progress.
                I only get a couple hours here and there to give her some love.
                Passenger side
                Clay bar
                Compounded
                Poilshed
                Waxed
                50/50 of the roof
                Upper part (drivers side) untouched
                Lower (passenger side)
                Clay
                Compound
                Etcetera
                  This piece here
                  There are 2 of these for the sheetmetal shift carrier mount. Did you remove these for the alum. carrier? I have an early g260 that I am using in my car now. I havent looked too far into whether I need to remove these or not.
                    From the reading I have done, if you swap from the sheet metal carrier to the aluminum style you still need to put a bolt with some sealant in the 2 holes on the back of the transmission or it will leak out of them.  The late ones are blind holes so a plug isn't necessary.
                      I remember reading long ago that if the bolt is too long it will interfere with the internals
                        Doorman
                        This piece here
                        I stayed with the sheet metal carrier.
                        The bolts are 2 different lengths, keep that in mind.
                        I have also read they need to be reinstalled when changing to the aluminum carrier.
                          Doorman
                          Front suspension overhaul kit from ECS arrived today!!
                          Damn heavy box too!
                          Got the kit with tie rods and upper strut mounts also.
                          Grabbed some trans mounts because the old ones are mushy.
                          Any pointers on the suspension stuff??
                          Looks pretty cut and dry.
                            Should be pretty straightforward. For the lollipops I lube with dishsoap to get them on the rear of the control arm. You are supposed to install quickly and set the car down so they "glue" themselves in place with no twisting at ride height. The old ones should pull off with a a 3 jaw puller.
                            Sent from my potato phone
                              Doorman
                              Drivers side out!!!
                              Took me about an hour and a half including jacking up the car, jack stands, both tires off etc.
                              daughter is napping and wife's at work. I may save the other side for when she gets home......she says she wants to help!!
                              Used my harbor freight ball joint tool for the tie rod and control arm joints. The 3' extension and 4 wacks with a hammer took care of the inner joint.
                              All joints are "mushy" and easily moveable by hand.
                                Very cool, how do you plan on installing the control arms into the new bushings?
                                  Doorman
                                  I'll use some threaded rod and some angle iron and a 4" square plate with a hole in it
                                    Right on, thats how I did it. I recommend greasing the threads
                                      You are talking about the lollipops right? I mount the control arm to the car then with dishsoap they go right on, it is tight but can be done by hand. Remember that they need to go on and be lubricated until the cars weight is on the suspension.
                                        I clamped the lolipop in a vice and used dishsoap and water solution (probably close to 50/50 ratio) and then pushed the arm into it. I just eye-balled the angle, so it probably wasn't optimal. It wasn't easy or fun, so make sure you put them on the right way the first time... facepalm.gif
                                          Doorman
                                          All new parts are on the car!!!
                                          I'll get everything torqued up tomorrow.
                                          A couple issues.
                                          Broke a stud in the u bracket that the sway bar link bolts too. I'll grind it off tomorrow and replace the bolt.
                                          Tie rod ends have approx 1" too much thread on them. I'll grab a nut from Lowes or Ace tomorrow and thread it on then cut the extra threads off. I didn't replace the inner part because it has no play and looks better quality then the ones from ECS. Boots are perfect as well.
                                          A bit of dish soap and I pushed and twisted a bit to get the lollipops on the control arms.
                                          What does everyone use to torque the inner control arm nuts?
                                          Crows foot?
                                          It's the one that's up above the subframe.
