Doormans e30 325e
From the reading I have done, if you swap from the sheet metal carrier to the aluminum style you still need to put a bolt with some sealant in the 2 holes on the back of the transmission or it will leak out of them. The late ones are blind holes so a plug isn't necessary.
This piece here
There are 2 of these for the sheetmetal shift carrier mount. Did you remove these for the alum. carrier? I have an early g260 that I am using in my car now. I havent looked too far into whether I need to remove these or not.
I stayed with the sheet metal carrier.
The bolts are 2 different lengths, keep that in mind.
I have also read they need to be reinstalled when changing to the aluminum carrier.
Should be pretty straightforward. For the lollipops I lube with dishsoap to get them on the rear of the control arm. You are supposed to install quickly and set the car down so they "glue" themselves in place with no twisting at ride height. The old ones should pull off with a a 3 jaw puller.
Sent from my potato phone
Drivers side out!!!
Took me about an hour and a half including jacking up the car, jack stands, both tires off etc.
daughter is napping and wife's at work. I may save the other side for when she gets home......she says she wants to help!!
Used my harbor freight ball joint tool for the tie rod and control arm joints. The 3' extension and 4 wacks with a hammer took care of the inner joint.
All joints are "mushy" and easily moveable by hand.
Very cool, how do you plan on installing the control arms into the new bushings?
I'll use some threaded rod and some angle iron and a 4" square plate with a hole in it
You are talking about the lollipops right? I mount the control arm to the car then with dishsoap they go right on, it is tight but can be done by hand. Remember that they need to go on and be lubricated until the cars weight is on the suspension.
I clamped the lolipop in a vice and used dishsoap and water solution (probably close to 50/50 ratio) and then pushed the arm into it. I just eye-balled the angle, so it probably wasn't optimal. It wasn't easy or fun, so make sure you put them on the right way the first time...
All new parts are on the car!!!
I'll get everything torqued up tomorrow.
A couple issues.
Broke a stud in the u bracket that the sway bar link bolts too. I'll grind it off tomorrow and replace the bolt.
Tie rod ends have approx 1" too much thread on them. I'll grab a nut from Lowes or Ace tomorrow and thread it on then cut the extra threads off. I didn't replace the inner part because it has no play and looks better quality then the ones from ECS. Boots are perfect as well.
A bit of dish soap and I pushed and twisted a bit to get the lollipops on the control arms.
What does everyone use to torque the inner control arm nuts?
Crows foot?
It's the one that's up above the subframe.
Lots of patience with an open end wrench if I recall correctly.
Did you torque it to spec or just tighten the shit out of it?
The drivers side wasnt an issue but on the passenger side I had two different 22mm wrenches and took turns with each one/whichever one fit without interfering. Turn it a few degrees, then use the other one. Quite tedious
That was the worst one to get off.
I'll take both of your guys advise and crank them down.
I cut a 22mm wrench in half and used a another box wrench and piggy backed it. Those bolts are never fun!
I cut a 22mm wrench in half and used a another box wrench and piggy backed it. Those bolts are never fun!Sent from my iPhone using Tapatalk
Craftsman 22" wrench was all I had that fit.
Bought a ratchet wrench.....too big a head.
Everything in the front feels nice and tight after a test drive. Gonna get an alignment this week.
I knew I had a bad wheel bearing.....
Drivers side felt like gravel on disassembly.
After all the new bushings it's louder then ever!!
Gonna grab one this week.
