  4. Doormans e30 325e
Doormans e30 325e
115 Posts 14 Posters 2.0k Views 1 Watching
    not enough room for flex heads. I just use a regular open end on top to hold the bolt and tighten the nut on bitten with a ratchet. Your on the right route by taking off the exhaust, driveshaft and quibo.
      Doorman
      Triumphant success!!!
      Finished up earlier today, showered and took the wife and one daughter out for dinner.
      Of course we took the e30!!
      Shifts fantastic now.
      Wife drove about 15 minutes and she loves it too.
      Pictures....
      Pre 86 build date sheet metal shift carrier
      Shifter out.
      Replaced the lower piece that the shifter sits in.
      Snap ring pliers were needed, and of course I had some in the work truck.
      Old part that attaches front of shift carrier to trans. New one in the right. There's two in the front and both were pretty wasted!! Both bolts were loose and the passenger side I took our by hand.
      Top of trans.
      It looks like I could have retrofitted an aluminum carrier based on the reading I have done.
      Next on the list is suspension and rims/tires.
        Doorman
        Dropped the front of the drive shaft and the rear of the exhaust.
          Doorman
          Ordered a new shift boot and ebrake boot from Nine Stitch in New York, he's also gonna give me a price on making a new houndstooth cover for my drivers seat. He expects it to be in the $300 range.
          Picked up a Harbor Freight 6" DA polisher. The DA gets some pretty good reviews from the detail guys online.
          Stopped at an Auto Body shop today on a recommendation from a mechanic next door (was fixing his door....hence "doorman"). Turns out the guy is into old BMWs!! Showed him pics of my hood/trunk and he said if I can't fix them wet sanding/polishing he'd paint them both for $500.
          Still scouring CL and checking around the forums for some 4x100 rims.
          Should be ordering suspension parts early February.
            It's always interesting who you find that is into BMW's, there are some quite unexpected ones.
              Doorman
              Busted out the Harbor Freight DA!!
              Did a test panel on the hood.
              Looked good so I started to go at the drivers side for a bit.
              7e622a3e14a5f403efc2bc7eaac883da.jpgdce1763be6180bca2072ee44ef15539c.jpgf6b5ff2f9d2d350139e2fbbbbf8454e7.jpg
              Don't know how well it's showing up in the pictures but in person it's nice!!
              Yellow pad
              Meg's ultimate compound
              Speed 4
              I may have to wet sand a bit on the leading edge.
                Nice results, it is amazing what a little work can bring out in some old paint.
                • M
                  M
                  michael1972
                  What is a harbour freight DA exactly? My e30's paint is definetly in need of some TLC.
                    Doorman
                    http://m.harborfreight.com/6-in-57-amp-heavy-duty-dual-action-variable-speed-polisher-69924.html?utm_referrer=direct%2Fnot%20provided
                      Doorman
                      Some more detailing progress.
                      I only get a couple hours here and there to give her some love.
                      Passenger side
                      Clay bar
                      Compounded
                      Poilshed
                      Waxed
                      50/50 of the roof
                      Upper part (drivers side) untouched
                      Lower (passenger side)
                      Clay
                      Compound
                      Etcetera
                        This piece here
                        There are 2 of these for the sheetmetal shift carrier mount. Did you remove these for the alum. carrier? I have an early g260 that I am using in my car now. I havent looked too far into whether I need to remove these or not.
                          From the reading I have done, if you swap from the sheet metal carrier to the aluminum style you still need to put a bolt with some sealant in the 2 holes on the back of the transmission or it will leak out of them.  The late ones are blind holes so a plug isn't necessary.
                            I remember reading long ago that if the bolt is too long it will interfere with the internals
                              Doorman
                              This piece here
                              I stayed with the sheet metal carrier.
                              The bolts are 2 different lengths, keep that in mind.
                              I have also read they need to be reinstalled when changing to the aluminum carrier.
                                Doorman
                                Front suspension overhaul kit from ECS arrived today!!
                                Damn heavy box too!
                                Got the kit with tie rods and upper strut mounts also.
                                Grabbed some trans mounts because the old ones are mushy.
                                Any pointers on the suspension stuff??
                                Looks pretty cut and dry.
                                  Should be pretty straightforward. For the lollipops I lube with dishsoap to get them on the rear of the control arm. You are supposed to install quickly and set the car down so they "glue" themselves in place with no twisting at ride height. The old ones should pull off with a a 3 jaw puller.
                                  Sent from my potato phone
                                    Doorman
                                    Drivers side out!!!
                                    Took me about an hour and a half including jacking up the car, jack stands, both tires off etc.
                                    daughter is napping and wife's at work. I may save the other side for when she gets home......she says she wants to help!!
                                    Used my harbor freight ball joint tool for the tie rod and control arm joints. The 3' extension and 4 wacks with a hammer took care of the inner joint.
                                    All joints are "mushy" and easily moveable by hand.
                                      Very cool, how do you plan on installing the control arms into the new bushings?
                                        Doorman
                                        I'll use some threaded rod and some angle iron and a 4" square plate with a hole in it
                                          Right on, thats how I did it. I recommend greasing the threads
