  4. 1995 M3 S52 track drift car build
39 Posts 13 Posters 717 Views 1 Watching
  • C
    C
    CHRIS
    Wonder if it is Andys old car
    How many black E36 M3's has he had?
      Two
      • E
        E
        e36t-yost
        anyone know someone selling s52 cams and trays???? the guy i bought the car said he was going to get me some but thats if he remembers and when oh god i don't want to know so plzzzz it'd be a huge help
          I'm not sure if I missed something but what happened to the original cams?
            Did you try removing them but didn't remove them properly, causing them to crack?
              That wouldn't be good. One thing that is on my list of ideas is making something similar to the factory tool that pushed down on the cam and tray evenly so you don't have to sit there for 2 hours trying to slowly tighten the damn things down.
                I did my intake cam without any trouble without special tools.  I turned it so only cylinder one had pressure on the valves and with someone holding the square with a crescent wrench so it wouldn't turn suddenly removed all of the other caps.  Then I released cylinder one a quarter turn at a time.  I don't know how close to the line I was though?  I removed my m50 intake cam and installed an m54b30 cam in it's place.
                • E
                  E
                  e36t-yost
                  they weren't in the motor or the boxes of parts i assume he either kept them or lost them when he tore the motor apart or sold them way back when he took it apart because he was going to do a full build but never put it back together
                  • E
                    E
                    e36t-yost
                    so here are finally some photos of the 95 m3 i got finally figured out the picture upload thing haha
                    post-3550-0-87018700-1422134151thumb.jp
                    post-3550-0-54657600-1422134174thumb.jp
                    post-3550-0-46358400-1422134195thumb.jp
                    post-3550-0-96168300-1422134247thumb.jp
                      Valve cover in the front seat is a good sign ;) the body looks clean from the pics.
                      Sent from my potato phone
                      • E
                        E
                        e36t-yost
                        so i picked up some 328 cams for cheap with a whole motor that ate a couple valves to put in the m3 to get it running because m3 cams are just ridiculously expensive and the duration is slightly longer with the 328 cams with a  slightly shorter lift but i think i'll live with it once i get my tax return back, I'm ordering piston rings, new bearings, get the block hot tanked, and honed, and possibly port and polish the head. and probably coil overs on the suspension side of the project
                          Interested for results. Probably going to cut power a lot.
                          • E
                            E
                            e36t-yost
                            Ik it will probably hurt power but I'm just going with it for now to get the motor together with the turbo and completely rebuilt. from what i've heard from some people is that the cams may help with the turbo setup with the slightly longer duration. but this is my first go round i want to get it together, and see how i like it and go from there
                              Don't waste your time with the 328 cams, do it right the first time. Stock s52 cams aren't that expensive. If the cost of them is that big of a deal, a turbo build is out of the question.
                                Don't waste your time or money on the m52 cams
                                  deek10sn
                                  This turbo build is starting to sound like a pipe dream. I went full custom...best bet for is buy a used kit off bfc...start saving them nickles!!!
                                  • E
                                    E
                                    e36t-yost
                                    meh not so much a pipe dream just saving up to buy what i need, i have a lead on a full AA turbo kit and am waiting on a response so thats where i stand right now, i've decided to stick with stock internals for this year and keep the power when done around 500 i think that'll be enough to mess with. I've been so busy with work its been hard to give the car any time but once i get the parts i'll make time for it
                                      You're all over the board man. I'd say slow your roll and figure out how you really want to do things, and go down that route. Don't build something you won't be happy with.
                                      And first of all, don't screw around with refreshing stock motors. You can come buy an m50/52
                                      From me, or some junkyard for very very cheap, not open it up, and have plenty of fun all summer. Gotta realize you can make stupid power especially with e85.
                                      And throw away those cams man.
                                      And where did the diy approach go? What's the fun of buying a kit? If I was him, I would have borrow my friends mig welding or something and tac together a manifold, and downpipe, and pay some kid 100$ to weld up my intercooler piping. That's a whole 500$ total. And a whole lot more rewarding.
                                      And then now there is stock Ecu tuning, for very close to nothing, and I could get you setup on a base tune as well.
                                      This is all very affordable, just spend your money wisely.
                                        This is ironic coming from you.
