<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[1995 M3 S52 track drift car build]]></title><description><![CDATA[<p dir="auto">So i got a 1995 M3 with 99km on it because the odometer switched to that because the battery was dead when i bought it, but anyways, the s52 is in pretty poor condition right now the previous owner tore it apart to do a different turbo setup and never put it on or put it back together so theres some rust inside the pistons and on the cylinder walls, i cleaned up most of the rust with some fine steel wool to take the majority of it off, but now I'm planning to do a full rebuild on the engine and i will be fully caging the car, as well as tubbing the front strut towers, i just pulled the engine out tonight and am going to start disassembling it when i get time, but i was wondering if anyone knows of what brands i should go with for the full rebuild, i'll be using the stock pistons and rods but most everything i want to upgrade so i don't have to worry about it. if anyone has any leads or info to help me out that would be greatly appreciated.</p>
]]></description><link>https://wibimmers.com/topic/3383/1995-m3-s52-track-drift-car-build</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:00:30 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/3383.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 28 Dec 2014 07:36:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 1995 M3 S52 track drift car build on Mon, 23 Mar 2015 21:27:31 GMT]]></title><description><![CDATA[<p dir="auto">I agree cutting corners hasn't gotten me anywhere and it seems like learning things is never easy! My only addition is tools, having the right ones help a great deal.</p>
]]></description><link>https://wibimmers.com/post/56189</link><guid isPermaLink="true">https://wibimmers.com/post/56189</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Mon, 23 Mar 2015 21:27:31 GMT</pubDate></item><item><title><![CDATA[Reply to 1995 M3 S52 track drift car build on Sat, 21 Mar 2015 21:07:24 GMT]]></title><description><![CDATA[<p dir="auto">If you have any questions you can PM me.  From what I have learned over the years is do it right the first time.  Don't cut corners or cheap out because it will come back to haunt you. </p>
<p dir="auto">Weld or wire your oil pump nut, always torque down the bolt to their exact recommended spec, DON'T REUSE HARDWARE THAT IS MEANT FOR ONE-TIME USE.</p>
]]></description><link>https://wibimmers.com/post/56085</link><guid isPermaLink="true">https://wibimmers.com/post/56085</guid><dc:creator><![CDATA[DrLeadFoot]]></dc:creator><pubDate>Sat, 21 Mar 2015 21:07:24 GMT</pubDate></item><item><title><![CDATA[Reply to 1995 M3 S52 track drift car build on Sat, 21 Mar 2015 17:37:40 GMT]]></title><description><![CDATA[<p dir="auto">So you just want to blindly follow everyone else before you? Just because they say so? What happened to finding things out on your own, or doing it one way and finding there is a better way? Its not that someone should have told you, but maybe you didn't understand your initial goal well enough to begin with, and after learning more about it by doing it once you have more knowledge you can go back and rework it.</p>
<p dir="auto">Am I saying you shouldn't ask people for help or suggestions? Not at all.</p>
<p dir="auto">Do I expect everyone to be all puppies and daisies about it? Hell no.</p>
<p dir="auto">Do what you want, and if it doesn't work the first time you will find your mistakes, and learn from them.</p>
]]></description><link>https://wibimmers.com/post/56077</link><guid isPermaLink="true">https://wibimmers.com/post/56077</guid><dc:creator><![CDATA[GunMetalGrey]]></dc:creator><pubDate>Sat, 21 Mar 2015 17:37:40 GMT</pubDate></item><item><title><![CDATA[Reply to 1995 M3 S52 track drift car build on Fri, 20 Mar 2015 15:08:41 GMT]]></title><description><![CDATA[<p dir="auto">Nothing against the OP - but the initial post of "What brands should I use for the rebuild" already had me out of this thread.</p>
<p dir="auto">If there's one thing I've learned in my years of modifying cars... It's that the 90% of people saying "You won't" - are right.</p>
<p dir="auto">Build what you want - how you want it. If you want advice - simply ask... You'll likely get more opinions then you need.</p>
]]></description><link>https://wibimmers.com/post/56027</link><guid isPermaLink="true">https://wibimmers.com/post/56027</guid><dc:creator><![CDATA[ClassE]]></dc:creator><pubDate>Fri, 20 Mar 2015 15:08:41 GMT</pubDate></item><item><title><![CDATA[Reply to 1995 M3 S52 track drift car build on Fri, 20 Mar 2015 13:50:07 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/56018">GunMetalGrey said:</a></strong></p>
<p dir="auto">This is ironic coming from you.</p>
<p dir="auto">Ironic? Yes. Is it okay? No. Instead of helping this guy, you guys are just doing the same thing you kind of people did when I was starting down my path. Instead of encouraging this kid and telling him he can do it, and helping him gain knowledge instead of telling him he is doing it wrong and that it's all a "pipe dream"</p>
<p dir="auto">If 1/10th of the people who told me I'm an idiot, helped Me, I would be YEARS ahead of where I am now.</p>
<p dir="auto">For all you guys know, this kid could be totally capable, he just needs to be steered in the right direction. At least give him a chance to help him do it right.</p>
<p dir="auto">All the info is out there, it's just a matter of</p>
<p dir="auto">Finding the right info, and putting it into play. I spent thousands of dollars and countless hours redue-ing shit because I learned a better option down the road. And in the end all of those could have been avoided very easily if someone more knowledgeable just pointed me in the right direction sometimes.</p>
<p dir="auto">MAN I HATE PEOPLE. I like cars.</p>
]]></description><link>https://wibimmers.com/post/56024</link><guid isPermaLink="true">https://wibimmers.com/post/56024</guid><dc:creator><![CDATA[Rowleym]]></dc:creator><pubDate>Fri, 20 Mar 2015 13:50:07 GMT</pubDate></item><item><title><![CDATA[Reply to 1995 M3 S52 track drift car build on Fri, 20 Mar 2015 13:34:03 GMT]]></title><description><![CDATA[<p dir="auto"><img src="http://i.imgur.com/FcKk8xt.gif" alt="FcKk8xt.gif" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/56022</link><guid isPermaLink="true">https://wibimmers.com/post/56022</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Fri, 20 Mar 2015 13:34:03 GMT</pubDate></item><item><title><![CDATA[Reply to 1995 M3 S52 track drift car build on Fri, 20 Mar 2015 12:40:52 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/56014">Rowleym said:</a></strong></p>
<p dir="auto">You're all over the board man. I'd say slow your roll and figure out how you really want to do things,</p>
]]></description><link>https://wibimmers.com/post/56018</link><guid isPermaLink="true">https://wibimmers.com/post/56018</guid><dc:creator><![CDATA[GunMetalGrey]]></dc:creator><pubDate>Fri, 20 Mar 2015 12:40:52 GMT</pubDate></item><item><title><![CDATA[Reply to 1995 M3 S52 track drift car build on Fri, 20 Mar 2015 11:31:55 GMT]]></title><description><![CDATA[<p dir="auto">You're all over the board man. I'd say slow your roll and figure out how you really want to do things, and go down that route. Don't build something you won't be happy with.</p>
<p dir="auto">And first of all, don't screw around with refreshing stock motors. You can come buy an m50/52</p>
<p dir="auto">From me, or some junkyard for very very cheap, not open it up, and have plenty of fun all summer. Gotta realize you can make stupid power especially with e85.</p>
<p dir="auto">And throw away those cams man.</p>
<p dir="auto">And where did the diy approach go? What's the fun of buying a kit? If I was him, I would have borrow my friends mig welding or something and tac together a manifold, and downpipe, and pay some kid 100$ to weld up my intercooler piping. That's a whole 500$ total. And a whole lot more rewarding.</p>
<p dir="auto">And then now there is stock Ecu tuning, for very close to nothing, and I could get you setup on a base tune as well.</p>
<p dir="auto">This is all very affordable, just spend your money wisely.</p>
]]></description><link>https://wibimmers.com/post/56014</link><guid isPermaLink="true">https://wibimmers.com/post/56014</guid><dc:creator><![CDATA[Rowleym]]></dc:creator><pubDate>Fri, 20 Mar 2015 11:31:55 GMT</pubDate></item><item><title><![CDATA[Reply to 1995 M3 S52 track drift car build on Fri, 20 Mar 2015 01:26:52 GMT]]></title><description><![CDATA[<p dir="auto">meh not so much a pipe dream just saving up to buy what i need, i have a lead on a full AA turbo kit and am waiting on a response so thats where i stand right now, i've decided to stick with stock internals for this year and keep the power when done around 500 i think that'll be enough to mess with. I've been so busy with work its been hard to give the car any time but once i get the parts i'll make time for it</p>
]]></description><link>https://wibimmers.com/post/56004</link><guid isPermaLink="true">https://wibimmers.com/post/56004</guid><dc:creator><![CDATA[e36t-yost]]></dc:creator><pubDate>Fri, 20 Mar 2015 01:26:52 GMT</pubDate></item><item><title><![CDATA[Reply to 1995 M3 S52 track drift car build on Thu, 05 Feb 2015 21:54:26 GMT]]></title><description><![CDATA[<p dir="auto">This turbo build is starting to sound like a pipe dream. I went full custom...best bet for is buy a used kit off bfc...start saving them nickles!!!</p>
]]></description><link>https://wibimmers.com/post/53818</link><guid isPermaLink="true">https://wibimmers.com/post/53818</guid><dc:creator><![CDATA[deek10sn]]></dc:creator><pubDate>Thu, 05 Feb 2015 21:54:26 GMT</pubDate></item><item><title><![CDATA[Reply to 1995 M3 S52 track drift car build on Thu, 05 Feb 2015 18:06:02 GMT]]></title><description><![CDATA[<p dir="auto">Don't waste your time or money on the m52 cams</p>
]]></description><link>https://wibimmers.com/post/53811</link><guid isPermaLink="true">https://wibimmers.com/post/53811</guid><dc:creator><![CDATA[patsbimmer1]]></dc:creator><pubDate>Thu, 05 Feb 2015 18:06:02 GMT</pubDate></item><item><title><![CDATA[Reply to 1995 M3 S52 track drift car build on Wed, 04 Feb 2015 05:10:11 GMT]]></title><description><![CDATA[<p dir="auto">Don't waste your time with the 328 cams, do it right the first time. Stock s52 cams aren't that expensive. If the cost of them is that big of a deal, a turbo build is out of the question.</p>
]]></description><link>https://wibimmers.com/post/53731</link><guid isPermaLink="true">https://wibimmers.com/post/53731</guid><dc:creator><![CDATA[wasnt m3]]></dc:creator><pubDate>Wed, 04 Feb 2015 05:10:11 GMT</pubDate></item><item><title><![CDATA[Reply to 1995 M3 S52 track drift car build on Wed, 04 Feb 2015 03:04:55 GMT]]></title><description><![CDATA[<p dir="auto">Ik it will probably hurt power but I'm just going with it for now to get the motor together with the turbo and completely rebuilt. from what i've heard from some people is that the cams may help with the turbo setup with the slightly longer duration. but this is my first go round i want to get it together, and see how i like it and go from there</p>
]]></description><link>https://wibimmers.com/post/53722</link><guid isPermaLink="true">https://wibimmers.com/post/53722</guid><dc:creator><![CDATA[e36t-yost]]></dc:creator><pubDate>Wed, 04 Feb 2015 03:04:55 GMT</pubDate></item><item><title><![CDATA[Reply to 1995 M3 S52 track drift car build on Thu, 29 Jan 2015 21:47:45 GMT]]></title><description><![CDATA[<p dir="auto">Interested for results. Probably going to cut power a lot.</p>
]]></description><link>https://wibimmers.com/post/53505</link><guid isPermaLink="true">https://wibimmers.com/post/53505</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Thu, 29 Jan 2015 21:47:45 GMT</pubDate></item><item><title><![CDATA[Reply to 1995 M3 S52 track drift car build on Wed, 28 Jan 2015 03:42:43 GMT]]></title><description><![CDATA[<p dir="auto">so i picked up some 328 cams for cheap with a whole motor that ate a couple valves to put in the m3 to get it running because m3 cams are just ridiculously expensive and the duration is slightly longer with the 328 cams with a  slightly shorter lift but i think i'll live with it once i get my tax return back, I'm ordering piston rings, new bearings, get the block hot tanked, and honed, and possibly port and polish the head. and probably coil overs on the suspension side of the project</p>
]]></description><link>https://wibimmers.com/post/53354</link><guid isPermaLink="true">https://wibimmers.com/post/53354</guid><dc:creator><![CDATA[e36t-yost]]></dc:creator><pubDate>Wed, 28 Jan 2015 03:42:43 GMT</pubDate></item><item><title><![CDATA[Reply to 1995 M3 S52 track drift car build on Sun, 25 Jan 2015 02:00:31 GMT]]></title><description><![CDATA[<p dir="auto">Valve cover in the front seat is a good sign <img src="/assets/uploads/files/emoticons_default_wink.png" alt=";)" class=" img-fluid img-markdown" width="20" height="20" /> the body looks clean from the pics.</p>
]]></description><link>https://wibimmers.com/post/53235</link><guid isPermaLink="true">https://wibimmers.com/post/53235</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Sun, 25 Jan 2015 02:00:31 GMT</pubDate></item><item><title><![CDATA[Reply to 1995 M3 S52 track drift car build on Sat, 24 Jan 2015 21:18:10 GMT]]></title><description><![CDATA[<p dir="auto">so here are finally some photos of the 95 m3 i got finally figured out the picture upload thing haha</p>
<p dir="auto"><a href="/assets/uploads/files/monthly_01_2015_post-3550-0-87018700-1422134151.jpg"><img src="/assets/uploads/files/monthly_01_2015_post-3550-0-87018700-1422134151_thumb.jpg" alt="post-3550-0-87018700-1422134151thumb.jp" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
<p dir="auto"><a href="/assets/uploads/files/monthly_01_2015_post-3550-0-54657600-1422134174.jpg"><img src="/assets/uploads/files/monthly_01_2015_post-3550-0-54657600-1422134174_thumb.jpg" alt="post-3550-0-54657600-1422134174thumb.jp" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
<p dir="auto"><a href="/assets/uploads/files/monthly_01_2015_post-3550-0-46358400-1422134195.jpg"><img src="/assets/uploads/files/monthly_01_2015_post-3550-0-46358400-1422134195_thumb.jpg" alt="post-3550-0-46358400-1422134195thumb.jp" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
<p dir="auto"><a href="/assets/uploads/files/monthly_01_2015_post-3550-0-96168300-1422134247.jpg"><img src="/assets/uploads/files/monthly_01_2015_post-3550-0-96168300-1422134247_thumb.jpg" alt="post-3550-0-96168300-1422134247thumb.jp" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
]]></description><link>https://wibimmers.com/post/53211</link><guid isPermaLink="true">https://wibimmers.com/post/53211</guid><dc:creator><![CDATA[e36t-yost]]></dc:creator><pubDate>Sat, 24 Jan 2015 21:18:10 GMT</pubDate></item><item><title><![CDATA[Reply to 1995 M3 S52 track drift car build on Sat, 24 Jan 2015 21:13:15 GMT]]></title><description><![CDATA[<p dir="auto">they weren't in the motor or the boxes of parts i assume he either kept them or lost them when he tore the motor apart or sold them way back when he took it apart because he was going to do a full build but never put it back together</p>
]]></description><link>https://wibimmers.com/post/53210</link><guid isPermaLink="true">https://wibimmers.com/post/53210</guid><dc:creator><![CDATA[e36t-yost]]></dc:creator><pubDate>Sat, 24 Jan 2015 21:13:15 GMT</pubDate></item><item><title><![CDATA[Reply to 1995 M3 S52 track drift car build on Thu, 08 Jan 2015 23:28:50 GMT]]></title><description><![CDATA[<p dir="auto">I did my intake cam without any trouble without special tools.  I turned it so only cylinder one had pressure on the valves and with someone holding the square with a crescent wrench so it wouldn't turn suddenly removed all of the other caps.  Then I released cylinder one a quarter turn at a time.  I don't know how close to the line I was though?  I removed my m50 intake cam and installed an m54b30 cam in it's place.</p>
]]></description><link>https://wibimmers.com/post/52298</link><guid isPermaLink="true">https://wibimmers.com/post/52298</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Thu, 08 Jan 2015 23:28:50 GMT</pubDate></item><item><title><![CDATA[Reply to 1995 M3 S52 track drift car build on Thu, 08 Jan 2015 18:30:05 GMT]]></title><description><![CDATA[<p dir="auto">That wouldn't be good. One thing that is on my list of ideas is making something similar to the factory tool that pushed down on the cam and tray evenly so you don't have to sit there for 2 hours trying to slowly tighten the damn things down.</p>
]]></description><link>https://wibimmers.com/post/52283</link><guid isPermaLink="true">https://wibimmers.com/post/52283</guid><dc:creator><![CDATA[GunMetalGrey]]></dc:creator><pubDate>Thu, 08 Jan 2015 18:30:05 GMT</pubDate></item><item><title><![CDATA[Reply to 1995 M3 S52 track drift car build on Thu, 08 Jan 2015 14:32:19 GMT]]></title><description><![CDATA[<p dir="auto">Did you try removing them but didn't remove them properly, causing them to crack?</p>
]]></description><link>https://wibimmers.com/post/52279</link><guid isPermaLink="true">https://wibimmers.com/post/52279</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Thu, 08 Jan 2015 14:32:19 GMT</pubDate></item><item><title><![CDATA[Reply to 1995 M3 S52 track drift car build on Thu, 08 Jan 2015 13:50:27 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/52277">e36t-yost said:</a></strong></p>
<p dir="auto">anyone know someone selling s52 cams and trays???? the guy i bought the car said he was going to get me some but thats if he remembers and when oh god i don't want to know so plzzzz it'd be a huge help</p>
<p dir="auto">I'm not sure if I missed something but what happened to the original cams?</p>
]]></description><link>https://wibimmers.com/post/52278</link><guid isPermaLink="true">https://wibimmers.com/post/52278</guid><dc:creator><![CDATA[patsbimmer1]]></dc:creator><pubDate>Thu, 08 Jan 2015 13:50:27 GMT</pubDate></item><item><title><![CDATA[Reply to 1995 M3 S52 track drift car build on Thu, 08 Jan 2015 04:59:53 GMT]]></title><description><![CDATA[<p dir="auto">anyone know someone selling s52 cams and trays???? the guy i bought the car said he was going to get me some but thats if he remembers and when oh god i don't want to know so plzzzz it'd be a huge help</p>
]]></description><link>https://wibimmers.com/post/52277</link><guid isPermaLink="true">https://wibimmers.com/post/52277</guid><dc:creator><![CDATA[e36t-yost]]></dc:creator><pubDate>Thu, 08 Jan 2015 04:59:53 GMT</pubDate></item><item><title><![CDATA[Reply to 1995 M3 S52 track drift car build on Wed, 07 Jan 2015 00:15:34 GMT]]></title><description><![CDATA[<p dir="auto">Two</p>
]]></description><link>https://wibimmers.com/post/52223</link><guid isPermaLink="true">https://wibimmers.com/post/52223</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Wed, 07 Jan 2015 00:15:34 GMT</pubDate></item></channel></rss>
