  4. Rear end sideways bump
28 Posts 5 Posters 432 Views 1 Watching
  • M
    M
    michael1972
    No idea what shocks. Looked like oe BMW had a BMW sticker on them
    • M
      M
      michael1972
      And how would I know if they did or did not have the internal stop? If they didn't why would they not come with a external bump stop?
      • M
        M
        michael1972
        Well I called ECS who I got the KYB's from and the rears I have do have internal bump stops. Now my question for Earl would be, do the mustang shocks have the internal stops or will I need external stops to run them?
        • M
          M
          michael1972
          Earl would these be what I would want to try?
          http://m.advanceautoparts.com/mt/shop.advanceautoparts.com/p/monroe-sensa-trac-passenger-car-shock-absorber-5968/19710464-P?searchTerm=rear+shock
            A couple other things to think about. Did you replace the rear shock mounts? How did the rear towers look when you did the replacements (no tears in the metal)?
            Did you put everything together correctly (esp the orientation of the cupped washers)?
            http://www.turnermotorsport.com/pages/Instructions/rear_shock_assembly.pdf
            • M
              M
              michael1972
              Well now you have me second guessing. But I took the stuff off the one and put it on the other same way.
              • M
                M
                michael1972
                Was I supposed to reuse any of these parts? The KYB shock had a sleeve over the metal rod.
                post-2797-0-68085000-1420324025thumb.jp
                  That round rubber disk is your bump stop. The plastic sleeve will keep dirt and crap out of the shock and in the top of the sleeve is a metal cup washer open side down. See the Turner picture: which omits the bump stop and the sleeve.
                  Now all that said if the rear end wasn't dancing around when you got it the issue is the shock and spring combination.
                  • M
                    M
                    michael1972
                    Ok so I got to the bottom of the problem thanks to Boris. Here is what happened total installer error on my part. See pic number one. There was a small metal sleeve spacer on the original shocks see pic 2 that I put on the new shocks bad idea as you can see. Also I took the bottom washer off that came on the kyb shock see pic 3 and put it on the top. Result no bottom washer and the top washer stuck on top of the small spacer instead of on the mount. Took the spacer out and put the washer on the bottom and other washer on the top see last pic. Went for a long bumpy road drive and it is way better now. Thanks for the help guys.
                    post-2797-0-40043700-1420334867thumb.jp
                    post-2797-0-25232800-1420334901thumb.jp
                    post-2797-0-15596100-1420334980thumb.jp
                    post-2797-0-42044000-1420335020thumb.jp
                    • M
                      M
                      michael1972
                      Oh yea and my gaskets are totally rotted away. I am ordering some of the rienforcement plates asap.
                        Just stock replacements. I am not sure of they have internal stops. At your height you would never bottom them out anyways 😃 They are Gabriel Ultra brand
                        • M
                          M
                          michael1972
                          Ok so now I think I still have it wrong. Am I supposed to reuse the washer thats in the sleeve on the bottom side of the mount or since the kyb has a metal sleeve on the shock do I not use a washer at all on the bottom. Because what I think I have going on now is 2 top washers. One on bottom and one on top.
                            The PO on my 318is had kybs and reused the bottom stock cup washer under the mount (open side down like in the Turner diagram). The cup washers are the same top and bottom. The orientation on the install is the difference. See the picture.
                            When I put in the bilstein and h&r sports I followed the Turner diagram on assembly plus bought a set of stock rear plastic boots. Bilsteins don't have the Kyb metal sleeve and with a winter DD figured it would be good to keep the crap out of the shock.
                            Still think your bouncing has more to do with the RSM and/or the pairing of shocks and springs. Might help to have someone take a ride with you to figure out what's going on.
                            • M
                              M
                              michael1972
                              The ride is way better now. I was just thinking I still had the washers wrong. I don't want to leave it like that if the ride is good but still have it installed wrong. If that makes sense. If the top and bottom washers are the same then I do have them installed correctly. The old washer thats in the plastic boot looks to be bigger tho.
                                Good to that the ride is better.
                                As for washers being different sizes could be. As old as these cars are and the 'creativity' of POs and assorted hack mechanics you'd be surprised at what you find and don't find as you dig into the car.
                                • M
                                  M
                                  michael1972
                                  Here is what I have going on now on the bottom side. First 2 pics are left last pic is right side. They are installed according to the diagram. Topside washers have cupside down. As far as surprises I shouldn't have to many. Car was a one owner and he paid for all service from new and gave me records. From what I have looked at and what he could recall he didn't think the shocks were ever changed. I am not sure about that but all 4 corners were beyond blown out. So who knows maybe it was the one thing that got negelcted.
                                  post-2797-0-23383700-1420386114thumb.jp
                                  post-2797-0-44899700-1420386142thumb.jp
                                  post-2797-0-21535800-1420386170thumb.jp
                                  • M
                                    M
                                    michael1972
                                    Once again thanks for the help Boris.
