  4. shifter kit question
12 Posts 5 Posters 145 Views 1 Watching
  • jawaJ
    jawaJ
    jawa
    its not stock im pretty sure its not
      Now that I am awake I can see that it is square. However, the only benefit I can see is that it might be "weighted". Otherwise I see nothing beneficial
        Pretty crusty too, the shift lever is stock for sure. Not familiar with e36 selector rods.
        • jawaJ
          jawaJ
          jawa
          im not sure about the lever either,
          but the linkages have ZERO play with some sort of metal bushing insert in the ends of them
            Could just be some brass bushings. I'll try and look around today to see if I can find out what this is
            Edit: A quick search brings up nothing that square at all. Try cleaning it up with some scotch brite and see if there is engraving or stamping on it anywhere.
              I have seen that style before but I can't remember where. If it has minimal play that's the main thing. I could care less for a short throw but the uuc dssr makes for no wiggling is a great purchase.
              Sent from my potato phone
                I know I have seen that as well but the fact that it's not dssr makes me wonder if it's custom or just a cheap aftermarket that someone upgraded bushings on.  Any upgraded aftermarket is going to be dssr.
                The z3 and 6spd e36 m3's have the same style as a normal e36 so that rules those out.
                • jawaJ
                  jawaJ
                  jawa
                  got it cleaned up and took  some better pictures,
                  post-3259-0-95560600-1419381476thumb.jp
                  post-3259-0-43053700-1419381735thumb.jp
                  • jawaJ
                    jawaJ
                    jawa
                    any one have any further insight?
                    • jawaJ
                      jawaJ
                      jawa
                      finally found what it is
                      http://www.autosolutions.net/construction/contruction_index.html
