  4. E39 Project
E39 Project
269 Posts 35 Posters 0 Views 1 Watching
    Rowleym said:
    So what you are saying here, is the countless stock DME tuned turbo e36's and e46's are unsafe even though people have driven tens of thousands of miles and also daily drive those cars? I honestly can't believe that it doesn't work when so many people prove it. Hell they made over 1000whp on the stock e36 DME. I know there are other factory turbo cars with MAF based systems as well. What you said does make some sense to me though. Pv=nrt No? Haha.
    This is how I understand the DME, the ones I've seen have all had some sort of piggyback controller, or an archaic RRFPR.  I never claim to know everything, just explaining how I understand things.  I'm always eager to admit I'm wrong when I get to learn something new.
      In Maximum Boost, it is mentioned on the NSX install that there is a MAF signal blocker that blocks or maintains the signal to keep it from going out of limits under boost. Just mentioning that since it may be part of how it would work with stock ECU + MAF
        UPDATES!!!!!!!!
          Yes, Updates!
            I third that^
              AAAAAAH such a boner kill guys. I saw this thread updated and I was like WOOOOO and then I clicked and I was full of disappointment.
                Been so busy I haven't been up to visit.  The Passenger side manifold is fully welded and the mock-up for the drivers side is almost done.
                I have to finish the pin-out on the new ECU and then start designing the intake manifold.
                  In before Earl says "you're the man!"
                    You're THE man Robert=)
                      Found a pic I haven't posted yet.
                        Please tell me thats an adapter to the stock wiring harness.
                          it is.
                            More Pics.
                            Passenger Manifold Mounted:
                            Trans was in the way:
                            Drivers Manifold Mocked up:
                            Frame hole on Drivers side:
                              Seems like it's a tight fit. Looks proper.
                                How is that trans hole gonna be filled? Concave profile to match the pipe?
                                  Yes.
                                    Stunning work and brave problem solving skills going on here
                                      More Drivers Side header goodness
                                        Wow, that is all.
