  4. E39 Project
E39 Project
269 Posts 35 Posters 4.4k Views 4 Watching
    REKIII said:
    Stock DME Tuning wont work.....well it can, but not without a piggy back of some sort.  The DME has no input for boost pressure.  With a Supercharger you can use AlphaN tuning because everything is linear and mathematically sound.  Turbos are not.
    It simplys measures flow? MAF no? Many people tune this stock ecu so I know I'm not too wrong.
    We will be using a datalogger of some sort, and log the stock maf voltage, and also the ford MAF we will be using, and then I will swap out the stock one, and be able to monitor the increased amount of airflow.
      Yes, it measures mass airflow.  This is great as long as the pressure doesn't change.  Due to the constant weight of the earths atmosphere, the computer knows the pressure will never vary from 14.5 PSI.   So it measures Airflow, based on that pressure.  If the pressure increases, due to a turbo or supercharger, the Airflow can remain the same but the DME doesn't know that an increased air amount has entered the engine.
      ALL DME tuned supercharger kits on BMW's that used to be NA convert to alphaN.  This eliminates the MAF's and uses math to figure out airflow based on RPM.  Because a supercharger produces the same PSI at a particular RPM all the time, the equations can be figured out and this programmed in.
      Turbo's are a different beast.  They produce boost based on load.  If you are cruising at 4K RPM the turbos will produce 0 PSI but if you are accelerating, when the car hits 4K, the turbos could be producing any amount of PSI, based on many factors.  This is why Mas Air Pressure (MAP) must be measured in a turbo car.  Since these cars have no factory MAP sensor, one must be added and controlled, and have bearing on the fuel tables.
        I know of a corvette that has been switched to run speed density via an obd2 tuning software. Not sure how but it do.
          So what you are saying here, is the countless stock DME tuned turbo e36's and e46's are unsafe even though people have driven tens of thousands of miles and also daily drive those cars? I honestly can't believe that it doesn't work when so many people prove it.
          Hell they made over 1000whp on the stock e36 DME.
          I know there are other factory turbo cars with MAF based systems as well.
          What you said does make some sense to me though.
          Pv=nrt
          No? Haha.
            Rowleym said:
            So what you are saying here, is the countless stock DME tuned turbo e36's and e46's are unsafe even though people have driven tens of thousands of miles and also daily drive those cars? I honestly can't believe that it doesn't work when so many people prove it. Hell they made over 1000whp on the stock e36 DME. I know there are other factory turbo cars with MAF based systems as well. What you said does make some sense to me though. Pv=nrt No? Haha.
            This is how I understand the DME, the ones I've seen have all had some sort of piggyback controller, or an archaic RRFPR.  I never claim to know everything, just explaining how I understand things.  I'm always eager to admit I'm wrong when I get to learn something new.
              In Maximum Boost, it is mentioned on the NSX install that there is a MAF signal blocker that blocks or maintains the signal to keep it from going out of limits under boost. Just mentioning that since it may be part of how it would work with stock ECU + MAF
                UPDATES!!!!!!!!
                  Yes, Updates!
                    I third that^
                      AAAAAAH such a boner kill guys. I saw this thread updated and I was like WOOOOO and then I clicked and I was full of disappointment.
                        Been so busy I haven't been up to visit.  The Passenger side manifold is fully welded and the mock-up for the drivers side is almost done.
                        I have to finish the pin-out on the new ECU and then start designing the intake manifold.
                          In before Earl says "you're the man!"
                            You're THE man Robert=)
                              Found a pic I haven't posted yet.
                                Please tell me thats an adapter to the stock wiring harness.
                                  it is.
                                    More Pics.
                                    Passenger Manifold Mounted:
                                    Trans was in the way:
                                    Drivers Manifold Mocked up:
                                    Frame hole on Drivers side:
                                      Seems like it's a tight fit. Looks proper.
                                        How is that trans hole gonna be filled? Concave profile to match the pipe?
                                          Yes.
