pistonse30
    I got your back on that.
    As in you have a 2.93 LSD?
    I have also read that you can put an extra LSD clutch in the stock diff?
      DrLeadFoot said:
      As in you have a 2.93 LSD? I have also read that you can put an extra LSD clutch in the stock diff?
      Yes. for more lockup. you don't NEED a 2.93, but it would be a little nicer. Would be a good winter project though! And it will help the squirly-ness on straight line beans giving. The clutch packs, not the ratio.
      but seriously throw the getrag out. no need when zf's are better and cheaper.
        ^and heavier...
          Zf would be worth the couple extra pounds.
          Yes, I do have another 2.93.
            ^and heavier...
            When we are talking about making 600+ftlb I don't think the extra 20 lbs over nearly the center of the vehicle will matter lol. Getrag is a lost cause at that point anyway. And they shift so much nicer.
              Got a 2.79LSD from GunMetalGrey. Now doing research on ZF swaps now with a focus on which driveshaft to use. Any input from y'all would be great.
              Ordered a twin disk UUC clutch over the shopping weekend. Had a special deal going on. Got a t-shirt, clutch stop, Evo-3 shifter, braided slave cylinder line for free plus $100 off the order.
              Gearing up to make this a reliable freeway ride. Taking it cross country this summer.
                manual e36 m3 with the 4 bolt in the rear.
                Corrected because I spread wrong information( I HATE THAT)
                  Game time.
                  • T
                    T
                    tsweers89
                    Bout time you stepped up to the big leagues
                      The trans I need is a 96+ m3?
                        Yes. Came in e39 528i, e36 328i, 96+ e36 m3, z3 2.8, z3m coupe and roadster. Fill it with Redline MTL fluid.
                        • CMartC
                          CMartC
                          CMart
                          Nice progress.
                          Let me know if you ever stumble on another LSD. I will eventually need one once my 4.10 goes out.
                          Excursion 7.3
                          E30 LS1
                            CMart said:
                            Nice progress.
                            I have a 3.73 lsd with your name on it! GunMetalGrey has a couple also.
                              Need to get these (second item)
                              http://www.akgmotorsport.com/catalog/catalog.php?page=2&category=e30%20S50%2FM50%20Swap
                              Does anyone have a stock e30 transmission mount crossmember for sale?
                                DrLeadFoot said:
                                Need to get these (second item) http://www.akgmotorsport.com/catalog/catalog.php?page=2&category=e30%20S50%2FM50%20Swap Does anyone have a stock e30 transmission mount crossmember for sale?
                                Is this supposed to be a solid trans mount deal? I have a couple uhmw condor mounts attached to a crossmember sitting in my old swap car. But they are damn 1" thick uhmw with a clearance hole lol. A whole 3$ worth of material.
                                  They are stock e21 with a jacket surrounding the rubber I guess.
                                  I have the condor trans mounts now. I like them for driving around town and short beat runs but I'm planning on doing a cross country trip with my fiancée this summer and buzzing all the way to Cali isn't too appealing.
                                    I have plenty of solid trans mounts in the shop if anyone needs them.
                                      DrLeadFoot said:
                                      They are stock e21 with a jacket surrounding the rubber I guess. I have the condor trans mounts now. I like them for driving around town and short beat runs but I'm planning on doing a cross country trip with my fiancée this summer and buzzing all the way to Cali isn't too appealing.
                                      I see I see. Very understandable. What are you thinking for motor mounts?
                                      Whats the most stiff/least vibration? At least what the most soft mount thats okay with an FI system?
                                        I was going to keep the Condor engine mounts and run a stock-ish trans mount like I had before. It felt solid.
                                          Would an auto driveshaft from a 328i work?
