pistonse30
    Still trying to find the UUC Twin disc clutch... It's not in the basement or in the couch.
    Anyone have a good condition g260 trans? Mine is noisy when the clutch is out. Yes, I do have a new TOB. I'm guessing bad bearings inside the trans. It was noisy before the turbo.
    Or should I put new bearings in my trans? It has close to 300,000 on it.
      Thats the "Getrag rattle" (worn layshaft bearings). Mine does it a bit too, nothing any normal passenger in the car would notice. How bad is yours? As im sure you are aware it isnt anything to be concerned with other than the annoyance of the noise.
      There is/was a guy on the east coast that sold rebuilt transmissions (primarily for specE30) for about $800. Search for it on r3v
        See the classifieds on specE30.com, great rebuilds but price is now up to $1200!
          Mine is really loud and I don't know if I want to pay "That Company" that much money for old arse parts...
            100$ zf trans from dons sports cars(google them) and get the DS at the same time. Refresh the shift detents, seals, and throw that puppy in, and make some POWAAA
              Won't I have to get a 2.93 diff?
                Yes
                  I got your back on that.
                    As in you have a 2.93 LSD?
                    I have also read that you can put an extra LSD clutch in the stock diff?
                      DrLeadFoot said:
                      As in you have a 2.93 LSD? I have also read that you can put an extra LSD clutch in the stock diff?
                      Yes. for more lockup. you don't NEED a 2.93, but it would be a little nicer. Would be a good winter project though! And it will help the squirly-ness on straight line beans giving. The clutch packs, not the ratio.
                      but seriously throw the getrag out. no need when zf's are better and cheaper.
                        ^and heavier...
                          Zf would be worth the couple extra pounds.
                          Yes, I do have another 2.93.
                            ^and heavier...
                            When we are talking about making 600+ftlb I don't think the extra 20 lbs over nearly the center of the vehicle will matter lol. Getrag is a lost cause at that point anyway. And they shift so much nicer.
                              Got a 2.79LSD from GunMetalGrey. Now doing research on ZF swaps now with a focus on which driveshaft to use. Any input from y'all would be great.
                              Ordered a twin disk UUC clutch over the shopping weekend. Had a special deal going on. Got a t-shirt, clutch stop, Evo-3 shifter, braided slave cylinder line for free plus $100 off the order.
                              Gearing up to make this a reliable freeway ride. Taking it cross country this summer.
                                manual e36 m3 with the 4 bolt in the rear.
                                Corrected because I spread wrong information( I HATE THAT)
                                  Game time.
                                  • T
                                    T
                                    tsweers89
                                    Bout time you stepped up to the big leagues
                                      The trans I need is a 96+ m3?
                                        Yes. Came in e39 528i, e36 328i, 96+ e36 m3, z3 2.8, z3m coupe and roadster. Fill it with Redline MTL fluid.
                                        • CMartC
                                          CMartC
                                          CMart
                                          Nice progress.
                                          Let me know if you ever stumble on another LSD. I will eventually need one once my 4.10 goes out.
                                          Excursion 7.3
                                          E30 LS1
