  4. '08 535xi Coolant light on and running very rough & NOT DRIVEABLE
32 Posts 9 Posters 0 Views 1 Watching
    jockhater2 said:
    lucky. I have personally had 3.
    I think he meams on the n54
    • Bobdudeman1988B
      Bobdudeman1988B
      Bobdudeman1988
      I have yet to see a stock n54 blow one lolz
      • e92boostE
        e92boostE
        e92boost
        It's your water pump. And it's not an easy job to do.
        But it's a common thing you'll be okay lol
        Ben H.
        • jockhater2J
          jockhater2J
          jockhater2
          That makes more sense. Thanks for the clarification.
          • FullThrottle e46F
            FullThrottle e46F
            FullThrottle e46
            Well...we don't have the diagnosis yet : (
            It was towed to the shop yesterday and the mechanic said he'd let my Mom know by then end of the day today. I take it a water pump job will be less costly than a head gasket? Are replacement water pumps usually refurbished and not new due to cost? Please educate. Thanks everyone!
            • FullThrottle e46F
              FullThrottle e46F
              FullThrottle e46
              Have the intake valves ever been blasted?
              • FullThrottle e46F
                FullThrottle e46F
                FullThrottle e46
                No they haven't. I take it that it's recommended? How much $$?
                  if its the head gasket then you all owe me a muffin.
                  • FullThrottle e46F
                    FullThrottle e46F
                    FullThrottle e46
                    How 'bout a dozen.
                    • FullThrottle e46F
                      FullThrottle e46F
                      FullThrottle e46
                      Update: Head gasket is fine. The cooling system is fine too.
                      Diagnosis is: fuel injectors and repair estimate is
                      $1400 from this mechanic and that's with a labor rate of only $75/hr. He said that's what has been causing the shuddering, which is mainly felt when the engine is cold.
                        What about the coolant loss?
                        • T
                          T
                          tsweers89
                          Were are you located? I get employee pricing on parts and have oem isid scanner to initialize the new injectors if that in fact is the issue
                          • FullThrottle e46F
                            FullThrottle e46F
                            FullThrottle e46
                            I still am confused about why the coolant light was on (no overheat). There wasn't any coolant on the ground or a leak. The level in the expansion tank was at the lower ball which is the minimum. Besides running very rough out of nowhere it would barely idle and was stalling. The mechanic said it started for him (naturally!) and it ran so he drove it around for about 8mi. So what does the coolant light have to do with the fuel injector problem, or doesn't it?
                            • Bobdudeman1988B
                              Bobdudeman1988B
                              Bobdudeman1988
                              what light came on?
                              post-3533-0-06479700-1417703468thumb.jp
                              this one?^ means low coolant
                              or
                              post-3533-0-46459700-1417703496thumb.jp
                              this one?^ means overheating
                              post-3533-0-85641400-1417703915thumb.jp
                              ^(red color of this light means way overheated)
                              that could be a water pump on its way out.(all to common on the n5x motors..)
                              it is normal to top of a car every year or two...but it shouldn't need frequent fill ups on coolant.
                              • FullThrottle e46F
                                FullThrottle e46F
                                FullThrottle e46
                                The coolant light and after it first came on I checked the level in the expansion tank (engine was cold-car had been in garage 24hrs prior). The bobber's top ball was not quite level with the top of the opening of the expansion tank (indicating that it was not quite at the minimum level that it should be). So I added 50/50 up to the max indicator (where the lower ball on the bobber is level with the top of the opening of the expansion tank opening). Then I started it and it was a rough cold start and everything was fine for a few days. I went to start it after it had been in the garage for 24hrs and was even more rough and no sooner than I was 40ft away from the garage the coolant light came on and it was barely idling and stalled. So I got it back to the driveway, which was difficult and it was barely idling. Since the engine was cold I checked the coolant level in the expansion tank and it was at the max. The coolant was still on. There was no visible leak on the garage floor or anywhere under the hood all around the expansion tank and hoses..etc.
                                • FullThrottle e46F
                                  FullThrottle e46F
                                  FullThrottle e46
                                  • FullThrottle e46F
                                    FullThrottle e46F
                                    FullThrottle e46
                                    My apologies, somehow the beginning of my last post is missing. To clear up any confusion I started with this:
                                    "I started the car and it was a bit rough and 1/4 mi away from home the coolant light came on so I turned around and came right back home. I parked it in the garage where it is level."
                                    • Bobdudeman1988B
                                      Bobdudeman1988B
                                      Bobdudeman1988
                                      The top light in my post was on? If its full could be a bad coolant level sender, as long as ita full and no overheat id bet its alright. Let me know about the recall and if you need me to install injectors for you,
                                      • T
                                        T
                                        tsweers89
                                        Do you have the software to run codes and diagnose the issue? As it could be a HDP that is causing the misfires also. What about initializing the new injectors? DO you have oem bmw sftware to do this?
                                        • FullThrottle e46F
                                          FullThrottle e46F
                                          FullThrottle e46
                                          Yep top light. Is it easy to check that sender? Would it have come up as a fault and show on the BMW OBD reader/tool/apparatus/thingy? The guy did a scan I'm pretty sure. We're picking up the car in a few hrs so I'll hear it all straight from the horses mouth. Talk soon.
