  4. '08 535xi Coolant light on and running very rough & NOT DRIVEABLE
32 Posts 9 Posters 483 Views 1 Watching
    Although it could be many different things, it could be a bad head gasket. Both times it has happened to me it had very similar symptoms. No overheating, just rough running. While not the most convenient thing to do; draining some coolant from the engine and letting it settle in a transparent container for a few hours will generally reveal if the head gasket is bad and oil+coolant are mixing as you will see oil droplets or a distinct layer of oil on top of the coolant
    • FullThrottle e46F
      FullThrottle e46F
      FullThrottle e46
      So it would need to be put up on a hoist to access/open the the drain plug in the bottom of the expansion tank to drain some coolant out? A head gasket replacement is a pricey repair, right? We (I) do have a reputable mechanic I was referred to by a former BMW tech of 15 yrs and he said he'd be fine with installing our own parts.
        Yes, if it is a head gasket it can be quite an involved repair.
        Capturing some of the coolant should not require a lift, just a jack and jackstands. The ideal location to drain coolant from would be from the engine block drain plug (if that engine has one), otherwise a lower radiator hose is fine. By doing this there is a small risk that an air pocket will form in the cooling system that will need to be bled out, but in most cases the air bubble shouldnt be trapped.
        The mechanic you have a connection with may have the tools/willingness to do a cylinder leak-down test or some more official method for diagnosing the problem as a bad head gasket, but for someone like myself, this is a quick and easy way.
        • T
          T
          tsweers89
          Doubtful its a headgasket. Have never seen one go bad yet. Get the codes read and go from there.
          • FullThrottle e46F
            FullThrottle e46F
            FullThrottle e46
            I can't imagine it's the head gasket. I obviously just have very rudimentary knowledge about this but her car is impeccably taken care of and currently has 92K on it.
            One more thing, I don't know if this is related but for the past 2 months there has been some "hiccuping" on acceleration after it has sat overnight. It's as if the car hasn't warmed up yet and you feel like you should step on the gas more, for lack of a better explanation.
              Have the intake valves ever been blasted?
              • Bobdudeman1988B
                Bobdudeman1988B
                Bobdudeman1988
                Could be alot of things, water pump failure might be throwing the light, but a bad fuel pump or leaking injector or bad coils could cause the misfire, agree with tsweers, need codes..
                • jockhater2J
                  jockhater2J
                  jockhater2
                  lucky. I have personally had 3.
                    I think he meams on the n54
                    • Bobdudeman1988B
                      Bobdudeman1988B
                      Bobdudeman1988
                      I have yet to see a stock n54 blow one lolz
                      • e92boostE
                        e92boostE
                        e92boost
                        It's your water pump. And it's not an easy job to do.
                        But it's a common thing you'll be okay lol
                        Ben H.
                        • jockhater2J
                          jockhater2J
                          jockhater2
                          That makes more sense. Thanks for the clarification.
                          • FullThrottle e46F
                            FullThrottle e46F
                            FullThrottle e46
                            Well...we don't have the diagnosis yet : (
                            It was towed to the shop yesterday and the mechanic said he'd let my Mom know by then end of the day today. I take it a water pump job will be less costly than a head gasket? Are replacement water pumps usually refurbished and not new due to cost? Please educate. Thanks everyone!
                            • FullThrottle e46F
                              FullThrottle e46F
                              FullThrottle e46
                              • FullThrottle e46F
                                FullThrottle e46F
                                FullThrottle e46
                                No they haven't. I take it that it's recommended? How much $$?
                                  if its the head gasket then you all owe me a muffin.
                                  • FullThrottle e46F
                                    FullThrottle e46F
                                    FullThrottle e46
                                    How 'bout a dozen.
                                    • FullThrottle e46F
                                      FullThrottle e46F
                                      FullThrottle e46
                                      Update: Head gasket is fine. The cooling system is fine too.
                                      Diagnosis is: fuel injectors and repair estimate is
                                      $1400 from this mechanic and that's with a labor rate of only $75/hr. He said that's what has been causing the shuddering, which is mainly felt when the engine is cold.
                                        What about the coolant loss?
                                        • T
                                          T
                                          tsweers89
                                          Were are you located? I get employee pricing on parts and have oem isid scanner to initialize the new injectors if that in fact is the issue
