  4. TehRaydarlover's AWD lover
12v or dieixe30
156 Posts 15 Posters 3.2k Views 4 Watching
    I am so pumped for this project! Looking good so far!
    • TehRaydarloverT
      TehRaydarloverT
      TehRaydarlover
      Not sure how many of you are ix freaks but I got these a few days ago. They are ix specific front mud flaps... its kinda a big deal.
      10700308102058115078733625357170620583
      10005821102058115377541097224224728225
      15985581020581153935414955487336942503
        Id rock those in winter mode if i drove it in winter. Did you permanently abort the bracketry or will you weld up a new one?
        • TehRaydarloverT
          TehRaydarloverT
          TehRaydarlover
          Looking at them I believe the brackets are the same as the readily available rwd brackets sooo hopefully disaster averted.. if not I'll invest in some tin snips and make use of all of these soup cans I have laying around my computer desk.  :P
          • TehRaydarloverT
            TehRaydarloverT
            TehRaydarlover
            But srrussly these are stupid rare. I did a 3D scan of them at work today. Hopefully make some replicas.
            15049571020585834052414923291994374632
              Awesome! What did you use to scan them and how do you plan on making the replicas? Silicone? SLA? Photopolymer?
                How thin is the bracket?  Should be able to use glass bead blast to clean them up without damaging even thin metal then repaint.
                  YES! do you guys have a faro arm scanner?!?!?! I might have to get a 24v head scanned!
                  • TehRaydarloverT
                    TehRaydarloverT
                    TehRaydarlover
                    We used the Romer arm. I'm thinking once the scan is done and cleaned up cnc cut the master molds in aluminum then a injection mold. Not sure what material to use yet, haven't been able to do much research. The stuff is actually quite hard I would guess around 75A. I guess I'm open to suggestions on the material.
                    You can't really tell in the picture but they are pretty much shot, one is almost completely rusted through. If I can get them for a reasonable price I would like to just use rwd mounting brackets and modify them if needed.
                    We used a Romer arm for this but we also have a few long range 3D scanners. Ha 12v head scanning will get priority :P
                      Just a quick thought but they may not always have been as hard as they are now.
                      Sent from my potato phone
                        M20 cylinder head scan for cfd analysis plz
                        • TehRaydarloverT
                          TehRaydarloverT
                          TehRaydarlover
                          Just a quick thought but they may not always have been as hard as they are now. Sent from my potato phone
                          True, they seem about as hard as the rwd ones I have now, similar to like a boot soul.
                          • TehRaydarloverT
                            TehRaydarloverT
                            TehRaydarlover
                            Hey guys happy thanksgiving, here’s an update on the front diff project I’m working on.
                            The idea is to cut the walls of the pumpkin off one diff and weld them to another thus adding two more spider gears, basically sacrificing one diff to reinforce another. This will help to lessen the load on each gear. With adding the two more spider gears I need to cut the shaft the gears ride on in half and machine a support block to hold the free ends of the shafts. I took a few measurements and had the support block machined out of a “tool steel” I’m not exactly sure what type of steel it’s made out of, I got the material when I was at school, it was just advertised as tool steel.
                            The support block came out quite nicely. I was a little upset after having to wait about two months to get it back when the machine shop forgot about my order and temporarily lost the material I gave them, but when I did get it back it was no charge because of the wait, I was like, wat? Oh alright, thanks! haha
                            Alright easy stuff done, now for the complicated part. My plan is to bolt the crown gear back on and weld the sides of the pumpkin to the crown gear. Then cut off the top and bottom of the pumpkin. In my mind, the geometry of the additional spider gears is critical; you must retain the original gear fitment/lash or you will have increased wear and ultimately failure. By welding the sides of the pumpkin to the crown gear I can then (after some shaping/grinding) bolt the crown gear onto another diff, keeping the cups that the spider gears ride on in the correct position.
                            Now for the welding. The plan is to grind and shape the sides of the diff so everything bolts up without any interference. Then with the crown gear bolted to the diff tack weld the additional sides from the old diff to the new diff. Then cut the tack welds off of the crown gear and remove it. Then finish welding.
                            To ensure a good weld I need to know what material the diff is made of and come up with a weld procedure. To determine what kind of steel I’m dealing with I shot it with our Niton XRF Analyzer at work. It came back as 1215 carbon steel. This is kind of bad news because while 1215 has excellent machinability it doesn’t have very good weldability due to a high sulphur content. I don’t think it will be too much of an issue because it won’t take too much to hold the sides in there and the weld isn’t going to be seeing too much of a load, its mostly just holding the sides on there. We have some extremely skilled welders at work that I’m sure are more than capable of getting the job done. Here’s the print out from the XRF Analyzer if anyone is interested
                            After everything is welded up I would like to have it sent out for stress relieving but I don’t think it would be a good idea because I don’t want to mess with the gear heat treat or that it will distort or crack the case. Once its welded I may need to skim cut the crown gear fit turn on the diff to clean up any excess weld. Then it’s just a matter of pressing on some new bearings and resealing it, then I should be good to go.
                            Any input is welcome,
                            Ray
                              That's some great work and research so far=) We have a Niton XRF Analyzer at work as well. Which model do you guys have? They're awesome pieces of equipment
                              • TehRaydarloverT
                                TehRaydarloverT
                                TehRaydarlover
                                Thanks, not sure what model it is, I can check on monday.
                                • bfraser30B
                                  bfraser30B
                                  bfraser30
                                  This is awesome stuff! I'll have plenty of questions for you when I get to this point on my iX. Very interested in how your mudflap project works out.
                                  • TehRaydarloverT
                                    TehRaydarloverT
                                    TehRaydarlover
                                    Anytime! Depending on where your located, if you ever need help working on it hit me up.
                                      So is this all done to simply increase the strength of the front diff?
                                      Awesome project, and I like that analyzer.
                                      I'm sure you know this, but I would hope you check what kind of tool steel that is? I'm not even sure what it's doing so I can't really comment on how strong it needs to be.
                                      • TehRaydarloverT
                                        TehRaydarloverT
                                        TehRaydarlover
                                        Yeah that's the goal, should be able to handle pretty much everything I can throw at it when its done. Yeah I was going to shoot it just for fun. I don't think it will see a huge load its mainly just holding the shaft the spider gears ride on. I figured if it is some sort of tool steel it should be nice and hard and hopefully help keep the shafts aligned correctly.
                                        • TehRaydarloverT
                                          TehRaydarloverT
                                          TehRaydarlover
                                          Put in my LED fog lights and high beams. Quite the improvement in visibility with the LEDs vs. halogens:
                                          14411941020619639349526213497895023537
                                          Before anyone says anything about the pitting, I already have some cerium oxide on the way haha
                                          10869408102061963937752697839761915444
                                          10900043102062011385738867125327763933
                                          10873339102062011408139421315478049015
                                          Just lows:
                                          10869908102062011424539839089758605405
                                          lows with fogs:
                                          10887433102062011443740311348855342057
                                          Just lows:
                                          10887503102062011482141276478107167608
                                          Lows with fogs:
                                          10854453102062011504941842383934986342
                                          And lows with LED brights:
                                          15562771020620115265423826905601730650
