  4. Build Thread?
Build Thread?
    That is all good and dandy and easy enough to mess around with but obviously my base issue is heat soak. So that being said I may investigate getting the IAT sensor into the plastic manifold (less thermal conductivity) and then create a small heat shield for the sensor. I will play with some MS settings for now to attempt to "put a band aid" on the problem.
      If you run VEAL you can just set a custom filter  such as  "mat>90" so that it rejects any data collected with an intake temp over 90 degrees.
        That would be a good idea.
        I need to figure something out because when the IAT heatsoaks I get a nasty idle surge. That or it is caused by something else, but it won't surge idle on startup, only after driving.
          Did some driving yesterday, leaned out my AFR's a bit and suddenly it is super smooth. Still trying to figure out timing, and what it wants. Got rid of most of the idle surge!
          Session had to be cut short after I saw the oil temp gauge, 260 degrees is not okay.
            Took the E30 to the shop yesterday, its nice to be able to drive it through the city, but it was not without headache. I need an oil cooler pronto!
            Few shots from the infamous Mr. Spence
            153881997323058ab9bb7b.jpgBen's Turbo E30 by Jake Spence Photo, on Flickr
            1520217419020ed31c6d6b.jpgBen's Turbo E30 by Jake Spence Photo, on Flickr
              Cool pics ;)
              It was nice to see the car and new shop.
                I just glanced at the last picture I posted, I can't believe how high up in the car that exhaust is for being 3"....
                  Just means you can lower it=) Looks great Ben. Will we be seeing this ta the October Meet?
                    I am not sure, tuning is not as easy as I thought and finding someone to drive while I tune has proven to be tricky, mix in the fact that I get high oil temps and need to get that under control makes me think that it won't be there. Which saddens me.
                    Edit: straight from the Holset Book of goodness. MAX oil temp under any condition: 248F or 120C
                    I am getting oil temps a bit past that so I don't want to risk ruining the turbo as it is oil cooled.
                      Can't you fit a cooler before then? 😃
                        It's not the fitting that's the issue, it's the cost.
                        By the time I get the OFH Cap, fittings, hose, cooler and thermostat we are looking at ~$500
                          Did you check with snap to see what he is running? 😃
                            Are you looking at the $150 cap from IE?
                              IM RUNNING AN M20 BRO
                              but really, the M20B25 comes with an oil cooler from the factory so all I had to do was remove the old one, add AN fittings to the housing and mount up a bigger one.
                                Either the IE cap if it is the right size or the one from Rally Road
                                Though if this oil cooler deal takes me as long as it seems it will I may just take my spare OFH and see if it is feasible to just tap into one. Maybe make a plate and run an external oil filter? I dunno, we will see.
                                  Alas I have retired the car for the season again, but this time in a heated shop were it is more likely that I will work on it very frequently!
                                  The oil temp issues got the best of me and I am unable to fork over all of the cash required to put one in, along with the diff dumping a lot of oil I decided it was time again. Start build.
                                  Took off the front again in order to start fitting the oil cooler, forgot how much I hate having hoods on when working on cars. Took that off promptly and I am always annoyed by the hood hinge being half painted and dirty underneath, so I pulled all of that out and cleaned it real nice!
                                  Much better
                                  Started looking at the engine bay and was trying to figure out what I wanted to do with it. I have a few patches of mismatched paint from previous repair and some rust that I would like to replace by the ABS unit, luckily I can still buy the sheet metal that goes under the abs new from bmw for a price that is well worth it!
                                  Well, might as well do my annual engine pull and do things right!
                                  Started prepping the motor for pulling again and decided that I will do some bay shave and tuck followed by a respray so it will actually match my exterior! I also want to paint the core support because it is not really painted and it is visible from the outside of the car.
                                  The lowest cross beam in that picture, and most of the core support will be painted black.
                                  Goals
                                  Tuck this
                                  Catch can this
                                  Delete ABS and remove lines, make a better looking and more stealth brake fluid reservoir
                                  Also contemplating putting the fuse box in the cabin and running the engine harness straight into the firewall and not over the top of the engine.
                                  There, major details, I want to do some small stuff as well, like add a strut bar, replace my strut tops and whatnot, but those are short little projects!
                                  Picture of half of the shop for the kids
                                  • jockhater2J
                                    jockhater2J
                                    jockhater2
                                    I don't really see the vw in them. I like them a lot though. Simple yet sporty, and nice and clean.
                                    my vw has them...they are vw rims fo sho
                                      Ha, digging up some old stuff huh?
                                      Almost two years ago!
                                      • jockhater2J
                                        jockhater2J
                                        jockhater2
                                        lol yeah. After I replied I wanted to delete my post because of how long ago it was. But this forum doesn't let you delete your comments.
                                          I definitely support your decision of shaving and tucking=)
