pistonse30
    I see a lot of people running the crankcase vent to the exhaust. I have mine run to a catch can then to a port just downstream of the air filter.
    the turbo inlet is completely dry and oil free and the catch can is doing its job. So far so good. Not sure if its more of a concern on a 24v though.
      This is how I have my catch can setup too on my turbo m10.
        My point is, that if it is connected to the exhaust it is not a vacuum.  If it was then air would be going the wrong way through your exhaust system.  It may be a convenient way to get rid of the crankcase venting but it is not a vacuum.
          fluid moving past an orifice CAN produce a vacuum as molecules get dragged into the airstream. I believe the Dr said it had a check valve to keep from going the wrong direction when I was picking his brain on the matter.
             venturi effect=)
              Ahh, if it is a venturi device then that makes sense.  That didn't occur to me.  I would be curious to see with a gauge or manometer tube to see how much vacuum it produces at different engine speeds/loads.
                Got the crank sprocket off.
                The carnage:
                  is it a dual row chain for the cams, or is that sprocket strictly only for the oil pump?
                    One row is for the pump the other for the timing.
                    I'm glad I noticed these rounded off teeth. Worse than expected.
                      Is that normal tooth wear for those? or did something cause it to wear more severely?
                        Not normal at all. The chain flopping around when the pump snapped had to round them off.
                          Does anyone have a TDC flywheel locking pin?  Or could make one?
                          Specs:
                          http://www.advrider.com/forums/attachment.php?attachmentid=219972&stc=1&d=1258414732
                          I will be making my own camshaft lock tool:
                          http://forums.bimmerforums.com/forum/showthread.php?1814850-Cheap-DIY-Cam-locking-tool-for-Vanos-install
                          • T
                            T
                            tsweers89
                            Specs:
                            This is soo ghetto. hahaha. Why do this when you can go to concours and ask todd or burger to borrow them for the weekend or such. Not like they use them at the dealer everyday.
                              I'll do that!  Timmy, you are always pulling through!!
                                I will be getting the VAC harmonic dampener. I tried to order it today but they didn't have time to process my order. I called twice. Great products, phones... not so much.
                                  Got this over the weekend.
                                  Is anyone familiar with timing the S52 that could swing by my house and make sure I have it correct? Willing to pay $$$
                                    Thanks Jeff!!!!!
                                      Nice work jeff!
                                      • JeffJ
                                        JeffJ
                                        Jeff
                                        Thanks! Guys just got a new lathe last week hoping to have it running this week!
                                        1976 530i e12
                                        1990 325ix e30
                                        1992 325i e36
                                        1995 740il e38
                                        2001 330xi e46
                                        ^More to come :)
                                        • TehRaydarloverT
                                          TehRaydarloverT
                                          TehRaydarlover
                                          Just read the last 8 pages... life seems so much simpler without those 12 extra valves haha :P
