  4. crappy e36
crappy e36
64 Posts 10 Posters 0 Views 1 Watching
    I will get the measurements.  The only problem I can see with a solid mount is that it is not a purely rotational force.  I would think that it would be a good time to weld in rtab pocket reinforcements.
    • frcefedF
      frcefedF
      frcefed
      Definitely, I would reinforce the rtabs and anything else I can in conjunction with the subframe
        Just curious what benefits you think you might see out of a true coilover in the rear.
          AKG motorsport has excellent prices and the parts are good, they are what I used.
          • frcefedF
            frcefedF
            frcefed
            Easier adjustability, better limiting of wheel travel, I just think the e30/e36 rear suspension is outdated, I mean every other car in the world has struts or coilovers at every corner for a reason..
              Usually the race guys go to a true coilover in back for increased wheel travel and to use a tube style LCA.
              • frcefedF
                frcefedF
                frcefed
                I would think wheel travel is increased to a ridiculous amount with the stock setup in coilover form, what acts as a limiter with that setup? The shocks?
                  Yea its the shocks. I believe they typically run maybe 5" of travel and after lowering itbon the shock you decrease it further.
                  • frcefedF
                    frcefedF
                    frcefed
                    I've never heard of track cars having 5" of travel, even with rally cars that would seem like a lot. My coilovers on my e34 travel about an inch and if I adjusted them for 5" of travel they would basically ride like stock struts except with dampening capabilities.
                      Got the dimensions, here's a sketch i made.  Didn't have time to draw it in CAD.  It has to be a split design for assembly.  The poly ones have an aluminum sleeve through the center, the bolt is an m12.  My poly ones have a sleeve that is about 1" O.D. through the middle, now that I think about it, the sleeve is probably necessary because there needs to be rotation when the suspension compresses and the mount bracket locks down on whatever is in the center.  If you didn't have a sleeve then it would clamp down on the bushing and the rotation would be forced to happen at the O.D. of the bushing against the control arm.
                      ScannedfromaXeroxMultifunctionDevicezps
                      • frcefedF
                        frcefedF
                        frcefed
                        Looks good to me.
                          I fucking love you guys. You make my life so much easier haha.
                          I'll build some today!
                            Also. The split down the center is just flat? No recessed groves r anything?
                            So. Drill .975 or something close, and press in a 1" alum round stock with a 12mm hole, and exactly 49.25 tall?
                            • frcefedF
                              frcefedF
                              frcefed
                              Does the sleeve have to be wider than the 49.25 width?
                                The split is flat, OE bushing is not split, but these have to be 2 pieces to fit them into the control arm.  You could make the sleeve maybe .010ish (whatever that is in mm) longer than the 49.25mm, it is mainly so the bushing doesn't get pinched too tight, I would drill the center hole at a snug slip fit for the aluminum sleeve.  Between the bushing and the sleeve is where you want the rotation to happen when the suspension compresses.
                                • frcefedF
                                  frcefedF
                                  frcefed
                                  When does production start? Haha
                                    I'll build some this week! They will be Delrin.
                                    So... I can't do it for absolutely free.
                                    Price? They shouldn't take too long to machine!
                                    How many should I make?
                                    Might order stock to do a good batch of them.
                                    • frcefedF
                                      frcefedF
                                      frcefed
                                      I will take at least one set, let me know the price!
                                        Haha I'm asking how much I should charge for them, as I have no idea.
                                        • frcefedF
                                          frcefedF
                                          frcefed
                                          How much will it cost to make them and how much time will it take per set?
