pistonse30
    PM'd ya.  Might take a drive to Princeton today!
      Bearings ordered.  BOOM!!  well, hopefully not this time around.
      I wish making this car reliable was as easy as ordering parts.
      Everything I need is here or on its way this week to get this bolted back up ASAP the right way this time around.
      Now for some thinking out loud:
      I have been debating on going to a softer engine/trans mount to combat the vibes.  The vibes are both good and bad.  Good for me, bad for the bimmer.
      If I go MS3 I would use the S52 timing pickup that is in the engine block to reduce the rotating mass of the OBD 1 harmonic balancer timing pickup.
      Some properly offseted wheels to accommodate a lot of rubber so I'm gripping instead of bouncing the motor of the rev limiter every time acceleration is extreme.  If you know my name this is almost every time the right foot is on that GO pedal.  I will be borderline living underneath the rear suspension and in the trunk, watching for cracks and signs of stress, once there are bigger tires on there.  Hopefully the girlfriend will want to join me.
      There are more thoughts but the motor needs to be in the front of my mind.
        hilarious post :D
        Perhaps you have already read this, but its a good read
        http://www.atiracing.com/products/dampers/damper_dinan.htm
        What is your fuel cut set to with the TRM tune?
          Anyone have a Bentley manual and can look up what the spec is for the gap between the rod bearings and the journal is? Going to plastic gauge them soon.
            Both main and rod bearings should be .0008 - .0023" clearance measured with plastigage.
              Thank you!
                Is it .008-.023?
                .0008 seems really tight and plastic gauge doesn't go that small.
                  A sheet of paper is ~0.003" thick  to have something from the real world you can relate to
                  Pete McHenry suggests   ".0020"-.0025", with half a thousandth looser on the rear main"
                  per this post here  http://forums.bimmerforums.com/forum/showthread.php?775356-Main-Bearing-Clearances
                    IIRC Mine were about .0018.  Use the green that goes from .001-.003".
                      Plastic gauge day!
                      Wet sanded the #1 journal with this new-ish 3M paper that is equal to 1200 grit and 5w-30 to get rid of the slight scratch that I could feel with my finger.
                      A little Vaseline to hold it in place.
                      Got this bad boy dialed in to 25ft/lbs and 55 degrees.
                      Looks to be .001!! Thank god
                      For reference
                        nice! im sure it feels great to have checked it even though you could have said "screw it" and put it back together a few weeks ago.
                          Getting intense up in here, up in here.
                            Snap, I am glad I'm taking my time. I've noticed a couple of key issues especially the teeth of the crank sprocket being rounded off. If I was rushing I would probably have missed this and might have had it apart again in another 300 miles.
                              Where did you get the plasti gauge stuff from? I will need to do this when I start reassembling my spare block.
                                I have bought Plastigage from Napa before, you have to ask for it, it was in a pretty dusty box at my store lol.
                                • mkoeppM
                                  mkoeppM
                                  mkoepp
                                  I know NAPA has them. Any parts house should have them.
                                    All are torqued, three are in the pic.
                                      Pegasus Racing has the plastic gauge.
                                      • JeffJ
                                        JeffJ
                                        Jeff
                                        Nice to see people actually checking specs when there building motors.
                                        1976 530i e12
                                        1990 325ix e30
                                        1992 325i e36
                                        1995 740il e38
                                        2001 330xi e46
                                        ^More to come :)
                                          I'm just terrified that I'm going to blow this up so I need to do it the right way.
