  4. Turbo missing under load
78 Posts 14 Posters 1.6k Views 2 Watching
  • L
    L
    lagwagon
    Wait, if I'm understanding this correctly - you are running the war chip and stock injectors with the miller maf? Are you using the M50 base tune and then tuning to the turbo?
    • JeffJ
      JeffJ
      Jeff
      #24 injectors and using a 24 injector tune and changing it for the turbo stock maf. Need to Chang it
      1976 530i e12
      1990 325ix e30
      1992 325i e36
      1995 740il e38
      2001 330xi e46
      ^More to come :)
        24#ers are probably only going to support 8psi max before the duty cycle gets craycray. I bump 100% duty cycle at 12psi on 33#  injectors @43.5psi fuel pressure
        • L
          L
          lagwagon
          You are just going to pop that motor unless you get a proper tune in there. Get the miller maf ($300) and 60# siemens injectors ($220) and start with the base tune. It will probably solve all of your problems unless you have some underlying mechanical issues like the TPS
          • JeffJ
            JeffJ
            Jeff
            We'll understanding that my injectors are tiny it has been like this for over a year now no popped motor yet.
            I do agree in need to upgrade the injectors at least.
            I did figure out my issue though I loaded the wrong file into the chip. Have to tweak the tune in higher rpm at wot but back to the normal afr'a of 10.5-11 untill 5k where it goes to 12.5-13
            1976 530i e12
            1990 325ix e30
            1992 325i e36
            1995 740il e38
            2001 330xi e46
            ^More to come :)
              This. Im surprised you can even run lean with the injectors wide open and 10-12PSI.
              You should just buy my ms3x and be done with this war chip nonsense :)
                I completely agree.
                He is saving up for a bridgeport,
                something about a cordless drill welded to a tripod "isnt quite good enough"
                snobs.
                • JeffJ
                  JeffJ
                  Jeff
                  Lol damn right I may look and and see if I can find a used set of injectors ans long as I can get the tune for them
                  1976 530i e12
                  1990 325ix e30
                  1992 325i e36
                  1995 740il e38
                  2001 330xi e46
                  ^More to come :)
                    http://maksinjection.com/?product=bosch-0280-155-737-33-white
                    • L
                      L
                      lagwagon
                      I'm making over 500whp on the war chip reliably and the car runs great. Just get the proper setup and you'll be good.
                        I needed to set my plug gap to .22 to stop the break up. I know nada about the tune world though.
                          Did you ever find your turbo? In post #1 you stated that it was missing, I would like to think that the thieves returned it.
                          Please update!
                            ..and does the turbo just reappear when not under load? That must make some awesome noises with the manifold just dumping exhaust under load.
                            • JeffJ
                              JeffJ
                              Jeff
                              Please update!
                              Sadly I have not found it yet. It's like there's a worm hole that it goes to. Had the police department dust for prints and came up with nothing:(
                              1976 530i e12
                              1990 325ix e30
                              1992 325i e36
                              1995 740il e38
                              2001 330xi e46
                              ^More to come :)
                                You may be able to locate it using the compressor map.
                                In other news,I downloaded the WAR Chip software and loaded up the tune.
                                (ノ ゜Д゜)ノ ︵ ┻━┻
                                I quickly deleted all bits of the WAR Chip software off my computer after realizing that the values dont actually mean anything.
                                They create tunes on the dyno to come up with the values in the the tables which is why running different injector sizes besides the ones they have tunes for is not suggested. I would conclude that the WAR chip is meant purely for extending the redline, and going +/- from the meaningless values they provide you to get things fine tuned via guess and check.
                                The ignition table isnt even in degrees BTDC.  Some of the values are in the 60's and 70's.
                                Get some squirts.
                                • JeffJ
                                  JeffJ
                                  Jeff
                                  I'll trade you the war chip for the mega squirts seeing as I know how much you love the war chip
                                  1976 530i e12
                                  1990 325ix e30
                                  1992 325i e36
                                  1995 740il e38
                                  2001 330xi e46
                                  ^More to come :)
                                    Would you be interested in a ms3x?
                                    • JeffJ
                                      JeffJ
                                      Jeff
                                      I am but can send the money on it yet
                                      1976 530i e12
                                      1990 325ix e30
                                      1992 325i e36
                                      1995 740il e38
                                      2001 330xi e46
                                      ^More to come :)
                                        Great, what are you waiting for then
                                        • JeffJ
                                          JeffJ
                                          Jeff
                                          Lol sorry cant
                                          1976 530i e12
                                          1990 325ix e30
                                          1992 325i e36
                                          1995 740il e38
                                          2001 330xi e46
                                          ^More to come :)
