  3. BMW Discussion
  4. The official WHAT ARE YOU DOING TO YOUR BMW thread.
184 Posts 40 Posters 3.4k Views 1 Watching
    Going right now to pull a 3.25 dif from mikes parts car e28 to swap into the vert, should make it a heck of lot better for cruising/mpg.
      luckyyyyy,  I need to change out my 4.10 as well
        I pulled the windshield wiper arms and ducts, painted, and reinstalled. Lots of piddly detail work to do before Saturday!
          You have a 4.10 with all that power now?  I thought it was was too aggressive with the stock m20...  I believe Brian has a couple 3.25 difs that he is looking to get rid of with the shark car.
          • andyhundleyA
            andyhundleyA
            andyhundley
            I realized today that I will be needing a new water pump/ fan clutch in the near future. The temps creep up at idle.
            • I love my E39I
              I love my E39I
              I love my E39
              I found out i needed to replace my clutch fan the hard way when i didnt notice i had a softball sized hole through my radiator. And no fan blades left on my fan. :)
              Sent from my LG-LS970 using Tapatalk
              -Because Racecar-
                I love my E39 said:
                I found out i needed to replace my clutch fan the hard way when i didnt notice i had a softball sized hole through my radiator. And no fan blades left on my fan. :) Sent from my LG-LS970 using Tapatalk
                Been there... No fun but humorous now that I can tell people my car did it's own fan delete mod.
                • TehRaydarloverT
                  TehRaydarloverT
                  TehRaydarlover
                  I have this waiting for me when I get home. Left two weeks ago and literally pushed the axles in and shut the door haha. Started as just replacing a torn cv boot, things escalated quickly: rebuild front axles, steering rack, poly motor mounts, control arms w/m3 offset bushings, strut mounts, upgraded front drive shaft, new oil pan gasket, diffs tranny and transfer case flush, oil change, and just an all around cleaning. Almost ready for dd status.
                  10447771102046071650855455092653274104
                  • I love my E39I
                    I love my E39I
                    I love my E39
                    Have a new upper rad hose and coolant to install tomorrow finally after three weeks being down. Here is hoping thats the only place the coolant was leaking from.
                    -Because Racecar-
                    • JeffJ
                      JeffJ
                      Jeff
                      Umm I hooked up the drain tube in my e36 so it stops raining inside.
                      1976 530i e12
                      1990 325ix e30
                      1992 325i e36
                      1995 740il e38
                      2001 330xi e46
                      ^More to come :)
                      • I love my E39I
                        I love my E39I
                        I love my E39
                        Installed coolant hose and added coolant still leaking badly I think it may be thermostat housing? All iknow is it isnt overheating
                        -Because Racecar-
                        • i_love_carsI
                          i_love_carsI
                          i_love_cars
                          :shifty:
                          2007 Z4MR
                          2003 E39 M5
                          2002 E46 M3
                          2021 X5 40i
                          • dastuzD
                            dastuzD
                            dastuz
                            When are we tossing in the new Diff?
                            • i_love_carsI
                              i_love_carsI
                              i_love_cars
                              Installing Saturday afternoon
                              I also ordered forged diverter valves and charge pipe today
                              2007 Z4MR
                              2003 E39 M5
                              2002 E46 M3
                              2021 X5 40i
                              • 6670charger6
                                6670charger6
                                6670charger
                                Just blacked out the license plate recess, and installed a set of aftermarket taillight lenses in red/smoke.
                                Appleton, WI
                                • I love my E39I
                                  I love my E39I
                                  I love my E39
                                  I plastidipped my neon yesterday. Not a bmw update but still car related lol
                                  -Because Racecar-
                                  • i_love_carsI
                                    i_love_carsI
                                    i_love_cars
                                    Installed the LSD in the 1er today. Wow what a difference. Not much else to say. Probably the best mod I could have done given the power the car is currently making.
                                    Out with the old
                                    In with the new
                                    2007 Z4MR
                                    2003 E39 M5
                                    2002 E46 M3
                                    2021 X5 40i
                                      Relatively simple swap?
                                      • i_love_carsI
                                        i_love_carsI
                                        i_love_cars
                                        yeah the driveshaft nut was a PITA - i had a 52mm wrench but I think it's 50mm nut, so I had to wedge a stubby flathead screwdriver in to keep from rounding the nut. With a big enough pipe wrapped around the wrench it came off eventually. Other than that it was a pretty straightforward install.
                                        Some of the DIYs online involve dropping the entire driveshaft out, removing the exhaust - that's crazy. I just dropped one exhaust hanger on the back, then the front-most hanger on the axleback was welded on to a small plate that was attached to one of the mounting bolts for the differential, so I just undid that (cuz i had to anyway) and was able to slide that part of the exhaust off to the side and balance it (as seen in the photos). Just bent the heatshielld back a bit and had easy access to drop everything.
                                        First time doing it on this car and getting factory torqued bolts undone taking my time I finished in about 5 hours. Now I think it could be done in half that time. Probably 1.5 hours if you have air tools ( i don't :(  )
                                        2007 Z4MR
                                        2003 E39 M5
                                        2002 E46 M3
                                        2021 X5 40i
                                        • i_love_carsI
                                          i_love_carsI
                                          i_love_cars
                                          Evo 3 short shifter installed last night.
                                          I cursed a lot. I stabbed metal plates in the shifter housing so hard with a screwdriver that sparks flew.
                                          I eventually got everything installed with my wife helping me.
                                          I now know why everyone says for the 135i it's a PITA to install an STS. The instructions call for removing the driveshaft carrier and midpipes which certainly would have made it easier but also would have taken way longer. It's rather unnecessary.
                                          2007 Z4MR
                                          2003 E39 M5
                                          2002 E46 M3
                                          2021 X5 40i
