  3. BMW Discussion
  4. The official WHAT ARE YOU DOING TO YOUR BMW thread.
184 Posts 40 Posters 3.4k Views 1 Watching
  • TehRaydarloverT
    TehRaydarloverT
    TehRaydarlover
    I have this waiting for me when I get home. Left two weeks ago and literally pushed the axles in and shut the door haha. Started as just replacing a torn cv boot, things escalated quickly: rebuild front axles, steering rack, poly motor mounts, control arms w/m3 offset bushings, strut mounts, upgraded front drive shaft, new oil pan gasket, diffs tranny and transfer case flush, oil change, and just an all around cleaning. Almost ready for dd status.
    10447771102046071650855455092653274104
    • I love my E39I
      I love my E39I
      I love my E39
      Have a new upper rad hose and coolant to install tomorrow finally after three weeks being down. Here is hoping thats the only place the coolant was leaking from.
      Sent from my LG-LS970 using Tapatalk
      -Because Racecar-
      • JeffJ
        JeffJ
        Jeff
        Umm I hooked up the drain tube in my e36 so it stops raining inside.
        1976 530i e12
        1990 325ix e30
        1992 325i e36
        1995 740il e38
        2001 330xi e46
        ^More to come :)
        • I love my E39I
          I love my E39I
          I love my E39
          Installed coolant hose and added coolant still leaking badly I think it may be thermostat housing? All iknow is it isnt overheating
          -Because Racecar-
          • i_love_carsI
            i_love_carsI
            i_love_cars
            :shifty:
            2007 Z4MR
            2003 E39 M5
            2002 E46 M3
            2021 X5 40i
            • dastuzD
              dastuzD
              dastuz
              When are we tossing in the new Diff?
              • i_love_carsI
                i_love_carsI
                i_love_cars
                Installing Saturday afternoon
                I also ordered forged diverter valves and charge pipe today
                2007 Z4MR
                2003 E39 M5
                2002 E46 M3
                2021 X5 40i
                • 6670charger6
                  6670charger6
                  6670charger
                  Just blacked out the license plate recess, and installed a set of aftermarket taillight lenses in red/smoke.
                  Appleton, WI
                  • I love my E39I
                    I love my E39I
                    I love my E39
                    I plastidipped my neon yesterday. Not a bmw update but still car related lol
                    -Because Racecar-
                    • i_love_carsI
                      i_love_carsI
                      i_love_cars
                      Installed the LSD in the 1er today. Wow what a difference. Not much else to say. Probably the best mod I could have done given the power the car is currently making.
                      Out with the old
                      In with the new
                      2007 Z4MR
                      2003 E39 M5
                      2002 E46 M3
                      2021 X5 40i
                        Relatively simple swap?
                        • i_love_carsI
                          i_love_carsI
                          i_love_cars
                          yeah the driveshaft nut was a PITA - i had a 52mm wrench but I think it's 50mm nut, so I had to wedge a stubby flathead screwdriver in to keep from rounding the nut. With a big enough pipe wrapped around the wrench it came off eventually. Other than that it was a pretty straightforward install.
                          Some of the DIYs online involve dropping the entire driveshaft out, removing the exhaust - that's crazy. I just dropped one exhaust hanger on the back, then the front-most hanger on the axleback was welded on to a small plate that was attached to one of the mounting bolts for the differential, so I just undid that (cuz i had to anyway) and was able to slide that part of the exhaust off to the side and balance it (as seen in the photos). Just bent the heatshielld back a bit and had easy access to drop everything.
                          First time doing it on this car and getting factory torqued bolts undone taking my time I finished in about 5 hours. Now I think it could be done in half that time. Probably 1.5 hours if you have air tools ( i don't :(  )
                          2007 Z4MR
                          2003 E39 M5
                          2002 E46 M3
                          2021 X5 40i
                          • i_love_carsI
                            i_love_carsI
                            i_love_cars
                            Evo 3 short shifter installed last night.
                            I cursed a lot. I stabbed metal plates in the shifter housing so hard with a screwdriver that sparks flew.
                            I eventually got everything installed with my wife helping me.
                            I now know why everyone says for the 135i it's a PITA to install an STS. The instructions call for removing the driveshaft carrier and midpipes which certainly would have made it easier but also would have taken way longer. It's rather unnecessary.
                            2007 Z4MR
                            2003 E39 M5
                            2002 E46 M3
                            2021 X5 40i
                            • I love my E39I
                              I love my E39I
                              I love my E39
                              Contemplated taking the car to the shop since its been in the driveway since june... but I didnt and replaced rear drum on the riced out neon instead
                              -Because Racecar-
                                Where is your leak coming from? There has to be a gasket that didnt seal properly or something that was damaged during the refresh?
                                • I love my E39I
                                  I love my E39I
                                  I love my E39
                                  Well ill be vagye, its somewhere in the front and not upper or lower hose. And not headgasket. And not overheating just leaking out once reaches optimal temp
                                  -Because Racecar-
                                    You should be able to pinpoint the leak while it is running and then go from there. I am sure it is just a gasket that didn't seat well or something small.
                                    • I love my E39I
                                      I love my E39I
                                      I love my E39
                                      Hope so but i ran it for almost 30 mins and could not see the leak anywhere..
                                      -Because Racecar-
                                        I love my E39 said:
                                        Hope so but i ran it for almost 30 mins and could not see the leak anywhere.. Sent from my LG-LS970 using Tapatalk
                                        Idle for 30 or drive for 30?
                                        • I love my E39I
                                          I love my E39I
                                          I love my E39
                                          Idle for 30. With revs. And thats enough for the coolant to come leaking out under car.like steady drip/stream.
                                          -Because Racecar-
