  3. BMW Discussion
  4. The official WHAT ARE YOU DOING TO YOUR BMW thread.
184 Posts 40 Posters 3.4k Views 1 Watching
  • K
    K
    Kip
    I need to see more of this car. I really like it!
    Thanks Snap. I'm sure you'll see her at some point this summer.
    • I love my E39I
      I love my E39I
      I love my E39
      I blew out a foglight bulb..ebay bulb specials on the way in the mail
      Sent from my LG-LS970 using Tapatalk
      -Because Racecar-
        I drove the e34 today....that's about it=)
          Going right now to pull a 3.25 dif from mikes parts car e28 to swap into the vert, should make it a heck of lot better for cruising/mpg.
            luckyyyyy,  I need to change out my 4.10 as well
              I pulled the windshield wiper arms and ducts, painted, and reinstalled. Lots of piddly detail work to do before Saturday!
                You have a 4.10 with all that power now?  I thought it was was too aggressive with the stock m20...  I believe Brian has a couple 3.25 difs that he is looking to get rid of with the shark car.
                • andyhundleyA
                  andyhundleyA
                  andyhundley
                  I realized today that I will be needing a new water pump/ fan clutch in the near future. The temps creep up at idle.
                  • I love my E39I
                    I love my E39I
                    I love my E39
                    I found out i needed to replace my clutch fan the hard way when i didnt notice i had a softball sized hole through my radiator. And no fan blades left on my fan. :)
                    -Because Racecar-
                      I love my E39 said:
                      I found out i needed to replace my clutch fan the hard way when i didnt notice i had a softball sized hole through my radiator. And no fan blades left on my fan. :) Sent from my LG-LS970 using Tapatalk
                      Been there... No fun but humorous now that I can tell people my car did it's own fan delete mod.
                      • TehRaydarloverT
                        TehRaydarloverT
                        TehRaydarlover
                        I have this waiting for me when I get home. Left two weeks ago and literally pushed the axles in and shut the door haha. Started as just replacing a torn cv boot, things escalated quickly: rebuild front axles, steering rack, poly motor mounts, control arms w/m3 offset bushings, strut mounts, upgraded front drive shaft, new oil pan gasket, diffs tranny and transfer case flush, oil change, and just an all around cleaning. Almost ready for dd status.
                        10447771102046071650855455092653274104
                        • I love my E39I
                          I love my E39I
                          I love my E39
                          Have a new upper rad hose and coolant to install tomorrow finally after three weeks being down. Here is hoping thats the only place the coolant was leaking from.
                          -Because Racecar-
                          • JeffJ
                            JeffJ
                            Jeff
                            Umm I hooked up the drain tube in my e36 so it stops raining inside.
                            1976 530i e12
                            1990 325ix e30
                            1992 325i e36
                            1995 740il e38
                            2001 330xi e46
                            ^More to come :)
                            • I love my E39I
                              I love my E39I
                              I love my E39
                              Installed coolant hose and added coolant still leaking badly I think it may be thermostat housing? All iknow is it isnt overheating
                              -Because Racecar-
                              • i_love_carsI
                                i_love_carsI
                                i_love_cars
                                :shifty:
                                2007 Z4MR
                                2003 E39 M5
                                2002 E46 M3
                                2021 X5 40i
                                • dastuzD
                                  dastuzD
                                  dastuz
                                  When are we tossing in the new Diff?
                                  • i_love_carsI
                                    i_love_carsI
                                    i_love_cars
                                    Installing Saturday afternoon
                                    I also ordered forged diverter valves and charge pipe today
                                    2007 Z4MR
                                    2003 E39 M5
                                    2002 E46 M3
                                    2021 X5 40i
                                    • 6670charger6
                                      6670charger6
                                      6670charger
                                      Just blacked out the license plate recess, and installed a set of aftermarket taillight lenses in red/smoke.
                                      Appleton, WI
                                      • I love my E39I
                                        I love my E39I
                                        I love my E39
                                        I plastidipped my neon yesterday. Not a bmw update but still car related lol
                                        -Because Racecar-
                                        • i_love_carsI
                                          i_love_carsI
                                          i_love_cars
                                          Installed the LSD in the 1er today. Wow what a difference. Not much else to say. Probably the best mod I could have done given the power the car is currently making.
                                          Out with the old
                                          In with the new
                                          2007 Z4MR
                                          2003 E39 M5
                                          2002 E46 M3
                                          2021 X5 40i
