  3. Local Scene
  4. want my 530 programmed
21 Posts 6 Posters 342 Views 1 Watching
  • A
    A
    afstud
    In all seriousness where r u located and what would you reasonably want to do those things?
    • T
      T
      tsweers89
      Milwaukee area, dont know how much or even if im willing to do it. Just stating i have the capabilities to.
      • A
        A
        afstud
        well it would be cool if you could help me out because it seems no one else has the software around here and every dealer wants 3 arms and 6 legs to do it for something that takes like 15 mins....... all i pretty much want is DRLs off and switch to Xenon's, if your not sure how to do it i can find instructions too if thats whats steering you away from doing it.
        • T
          T
          tsweers89
          I work at a bmw dealer in milwaukee as a tech. I know exactly what your trying to do. Although i have yet to see a xenon function turn on it CKM. Its usually a programming retrofit. How much is the "dealer" going to charge you? Also fyi it doesn't take just 15min.
          • A
            A
            afstud
            well then i dont know if its the e39 thats different but i had an 02 325xi of mine programmed to have the alarm activated and that took about 5 mins from the time the guy hooked it up to starting the program went into the menu and unplugged it from my car, so i assumed and from what everyone else seems to say on the forums about it taking only a few minutes and they have done it, And people have done xenon conversion and had it programmed with just the GT1 in a matter of minutes too..... and the dealer usually wants to charge 80-150 for it, which is nuts.
            • T
              T
              tsweers89
              Our dealer would charge 1.5hrs @ $125 per hour, good luck in your search though. Not many people i know that can do it in the area.
              • A
                A
                afstud
                so you wont help a member out on the side ?
                • T
                  T
                  tsweers89
                  No, cant do that.
                  • e92boostE
                    e92boostE
                    e92boost
                    Can get it done for $30 a code... and it does take 15 mins lol
                    Ben H.
                    • T
                      T
                      tsweers89
                      There you go. Have this guy help you. He seems real knowledgeable. Lol
                      • A
                        A
                        afstud
                        i might just buy this module for 30 bucks off this website that connects to the laptop, that almost 80% of the E46 fanatic community seems to have and takes them at most 15 mins to program a few things.
                        • e92boostE
                          e92boostE
                          e92boost
                          Your a funny guy, How hard can hooking up an autologic and switching some codes on and off be? It doesn't take a genius to know this... Unless all you do at the stealer is change oil lol
                          Ben H.
                          • SnyperxS
                            SnyperxS
                            Snyperx
                            Well for the record I coded my e90 without issue. I bought a cable that recommended off another site for $85 and used NCSExpert for the coding software. I did the corner delete and warm/cold bulb checking so I won't get errors with my LED lighting.
