  3. Local Scene
  4. want my 530 programmed
21 Posts 6 Posters 343 Views 1 Watching
  • T
    T
    tsweers89
    I work at a bmw dealer in milwaukee as a tech. I know exactly what your trying to do. Although i have yet to see a xenon function turn on it CKM. Its usually a programming retrofit. How much is the "dealer" going to charge you? Also fyi it doesn't take just 15min.
    • A
      A
      afstud
      well then i dont know if its the e39 thats different but i had an 02 325xi of mine programmed to have the alarm activated and that took about 5 mins from the time the guy hooked it up to starting the program went into the menu and unplugged it from my car, so i assumed and from what everyone else seems to say on the forums about it taking only a few minutes and they have done it, And people have done xenon conversion and had it programmed with just the GT1 in a matter of minutes too..... and the dealer usually wants to charge 80-150 for it, which is nuts.
      • T
        T
        tsweers89
        Our dealer would charge 1.5hrs @ $125 per hour, good luck in your search though. Not many people i know that can do it in the area.
        • A
          A
          afstud
          so you wont help a member out on the side ?
          • T
            T
            tsweers89
            No, cant do that.
            • e92boostE
              e92boostE
              e92boost
              Can get it done for $30 a code... and it does take 15 mins lol
              Ben H.
              • T
                T
                tsweers89
                There you go. Have this guy help you. He seems real knowledgeable. Lol
                • A
                  A
                  afstud
                  i might just buy this module for 30 bucks off this website that connects to the laptop, that almost 80% of the E46 fanatic community seems to have and takes them at most 15 mins to program a few things.
                  • e92boostE
                    e92boostE
                    e92boost
                    Your a funny guy, How hard can hooking up an autologic and switching some codes on and off be? It doesn't take a genius to know this... Unless all you do at the stealer is change oil lol
                    Ben H.
                    • SnyperxS
                      SnyperxS
                      Snyperx
                      Well for the record I coded my e90 without issue. I bought a cable that recommended off another site for $85 and used NCSExpert for the coding software. I did the corner delete and warm/cold bulb checking so I won't get errors with my LED lighting.
