  3. Local Scene
  4. want my 530 programmed
21 Posts 6 Posters 342 Views 1 Watching
  • Ryan...R
    Ryan...R
    Ryan...
    What year is it, and what are you looking to get done? Programmed is a pretty broad subject; are you looking for a performance chip/tune, or something else?
      Blaine0002
      you mean im not the only 5 series on the board???? :3
      • T
        T
        tsweers89
        e34 535 and e28 m5 owner here.
        • A
          A
          afstud
          yea i should have been more specific, sorry guys, well id like to have my DRL's turned off, thats pretty much the only thing i can think of that i want done... is there any other cool things you can do to a e39? and who here has the software?
          • T
            T
            tsweers89
            I do, i have a GT1 with CKM(car key memory) capabilites
            • A
              A
              afstud
              tsweers89, where are you located? how much would you want to just turn my DRL's off and change my car to Xenon headlamps?
              • T
                T
                tsweers89
                $1,000,000 should about do it
                • A
                  A
                  afstud
                  In all seriousness where r u located and what would you reasonably want to do those things?
                  • T
                    T
                    tsweers89
                    Milwaukee area, dont know how much or even if im willing to do it. Just stating i have the capabilities to.
                    • A
                      A
                      afstud
                      well it would be cool if you could help me out because it seems no one else has the software around here and every dealer wants 3 arms and 6 legs to do it for something that takes like 15 mins....... all i pretty much want is DRLs off and switch to Xenon's, if your not sure how to do it i can find instructions too if thats whats steering you away from doing it.
                      • T
                        T
                        tsweers89
                        I work at a bmw dealer in milwaukee as a tech. I know exactly what your trying to do. Although i have yet to see a xenon function turn on it CKM. Its usually a programming retrofit. How much is the "dealer" going to charge you? Also fyi it doesn't take just 15min.
                        • A
                          A
                          afstud
                          well then i dont know if its the e39 thats different but i had an 02 325xi of mine programmed to have the alarm activated and that took about 5 mins from the time the guy hooked it up to starting the program went into the menu and unplugged it from my car, so i assumed and from what everyone else seems to say on the forums about it taking only a few minutes and they have done it, And people have done xenon conversion and had it programmed with just the GT1 in a matter of minutes too..... and the dealer usually wants to charge 80-150 for it, which is nuts.
                          • T
                            T
                            tsweers89
                            Our dealer would charge 1.5hrs @ $125 per hour, good luck in your search though. Not many people i know that can do it in the area.
                            • A
                              A
                              afstud
                              so you wont help a member out on the side ?
                              • T
                                T
                                tsweers89
                                No, cant do that.
                                • e92boostE
                                  e92boostE
                                  e92boost
                                  Can get it done for $30 a code... and it does take 15 mins lol
                                  Ben H.
                                  • T
                                    T
                                    tsweers89
                                    There you go. Have this guy help you. He seems real knowledgeable. Lol
                                    • A
                                      A
                                      afstud
                                      i might just buy this module for 30 bucks off this website that connects to the laptop, that almost 80% of the E46 fanatic community seems to have and takes them at most 15 mins to program a few things.
                                      • e92boostE
                                        e92boostE
                                        e92boost
                                        Your a funny guy, How hard can hooking up an autologic and switching some codes on and off be? It doesn't take a genius to know this... Unless all you do at the stealer is change oil lol
                                        Ben H.
                                        • SnyperxS
                                          SnyperxS
                                          Snyperx
                                          Well for the record I coded my e90 without issue. I bought a cable that recommended off another site for $85 and used NCSExpert for the coding software. I did the corner delete and warm/cold bulb checking so I won't get errors with my LED lighting.
