  4. e12 complete restoration fun
53 Posts 13 Posters 0 Views 1 Watching
    Mister Jeff. I do not know what you are saying due to your missing punctuation=(
    Unless you meant:
    "I'm not sure how I'm going to clean it. I really want to sand blast it, but it is very messy. I might do it anyways. I am going to stainless shot blast the parts that I am keeping. Most of the suspension will be replaced."
    I'll go with the ladder.
    I always thought acid dipping was where it is at for a restoration but I learned out that it takes away all of the inner rust proofing so it ends up to be a lot of work to do it right.  Spraying that wax stuff in the inner frame rails, sealing the seams/welds(?).  There probably is more to do than I know about.
    • JeffJ
      JeffJ
      Jeff
      Its not the first time Jeff has missed his period.
      well can't have to many periods going on at the same time now can you?
      1976 530i e12
      1990 325ix e30
      1992 325i e36
      1995 740il e38
      2001 330xi e46
      ^More to come :)
      • JeffJ
        JeffJ
        Jeff
        there are many ways to seal the inner frame rails. i usually use a piece of 1/4" brake line and an old paint gum to spray the inner rail with rubber coating. help at 120psi does wonders!!!
         dropped the front subframe
        also finished stripping out the engine bay finally.
        1976 530i e12
        1990 325ix e30
        1992 325i e36
        1995 740il e38
        2001 330xi e46
        ^More to come :)
          How are those bolts coming off with the rust?
          With all the old bimmers I've had, all e30s, rusty bolts were never a problem.  I can't say the same about my xj jeeps.  I probably broke every body bolt on those...
            superior German metallurgy,   no joke.
            • JeffJ
              JeffJ
              Jeff
              Surprisingly very easy only a couple bolts broke but they where very small
              1976 530i e12
              1990 325ix e30
              1992 325i e36
              1995 740il e38
              2001 330xi e46
              ^More to come :)
                It's true, the only bolts I have ever broken on my e36 were manifold to downpipe studs and the bolts for the rear trailing arm camber adjustment.  (Those ones suck bad to drill out)
                • JeffJ
                  JeffJ
                  Jeff
                  I shall update soon I'm not dead just busy
                  1976 530i e12
                  1990 325ix e30
                  1992 325i e36
                  1995 740il e38
                  2001 330xi e46
                  ^More to come :)
                    Glad I texted you yesterday Jeff=)
                    • JeffJ
                      JeffJ
                      Jeff
                      Me too I miss the forums work has been busy. We'll work and making stuff
                      1976 530i e12
                      1990 325ix e30
                      1992 325i e36
                      1995 740il e38
                      2001 330xi e46
                      ^More to come :)
                        Don't worry Jeff
                        This forum is like a creed song.
                        We are always here with arms wide open
