  4. e12 complete restoration fun
53 Posts 13 Posters 0 Views 1 Watching
  • JeffJ
    JeffJ
    Jeff
    DrLeadFoot said:
    A man named Jeff doing manly things.
    I like the progress! Are you going to sandblast the whole body and all suspension bits? Then get to the body work?
    I'm not sure how I'm going to clean it mint really want to sand blast very messy but I may. I am going to stainless shot blast parts I am keeping most suspension will be replaced
    1976 530i e12
    1990 325ix e30
    1992 325i e36
    1995 740il e38
    2001 330xi e46
    ^More to come :)
      Mister Jeff. I do not know what you are saying due to your missing punctuation=(
      Unless you meant:
      "I'm not sure how I'm going to clean it. I really want to sand blast it, but it is very messy. I might do it anyways. I am going to stainless shot blast the parts that I am keeping. Most of the suspension will be replaced."
        Its not the first time Jeff has missed his period.
          Unless you meant:
          I'll go with the ladder.
          I always thought acid dipping was where it is at for a restoration but I learned out that it takes away all of the inner rust proofing so it ends up to be a lot of work to do it right.  Spraying that wax stuff in the inner frame rails, sealing the seams/welds(?).  There probably is more to do than I know about.
          • JeffJ
            JeffJ
            Jeff
            well can't have to many periods going on at the same time now can you?
            1976 530i e12
            1990 325ix e30
            1992 325i e36
            1995 740il e38
            2001 330xi e46
            ^More to come :)
            • JeffJ
              JeffJ
              Jeff
              there are many ways to seal the inner frame rails. i usually use a piece of 1/4" brake line and an old paint gum to spray the inner rail with rubber coating. help at 120psi does wonders!!!
               dropped the front subframe
              also finished stripping out the engine bay finally.
              1976 530i e12
              1990 325ix e30
              1992 325i e36
              1995 740il e38
              2001 330xi e46
              ^More to come :)
                How are those bolts coming off with the rust?
                With all the old bimmers I've had, all e30s, rusty bolts were never a problem.  I can't say the same about my xj jeeps.  I probably broke every body bolt on those...
                  superior German metallurgy,   no joke.
                  • JeffJ
                    JeffJ
                    Jeff
                    Surprisingly very easy only a couple bolts broke but they where very small
                    1976 530i e12
                    1990 325ix e30
                    1992 325i e36
                    1995 740il e38
                    2001 330xi e46
                    ^More to come :)
                      It's true, the only bolts I have ever broken on my e36 were manifold to downpipe studs and the bolts for the rear trailing arm camber adjustment.  (Those ones suck bad to drill out)
                      • JeffJ
                        JeffJ
                        Jeff
                        I shall update soon I'm not dead just busy
                        1976 530i e12
                        1990 325ix e30
                        1992 325i e36
                        1995 740il e38
                        2001 330xi e46
                        ^More to come :)
                          Glad I texted you yesterday Jeff=)
                          • JeffJ
                            JeffJ
                            Jeff
                            Me too I miss the forums work has been busy. We'll work and making stuff
                            1976 530i e12
                            1990 325ix e30
                            1992 325i e36
                            1995 740il e38
                            2001 330xi e46
                            ^More to come :)
                              Don't worry Jeff
                              This forum is like a creed song.
                              We are always here with arms wide open
