  4. e12 complete restoration fun
53 Posts 13 Posters 926 Views 3 Watching
    Jeff said:
    I'm not sure how I'm going to clean it mint really want to sand blast very messy but I may. I am going to stainless shot blast parts I am keeping most suspension will be replaced
    Mister Jeff. I do not know what you are saying due to your missing punctuation=(
    Unless you meant:
    "I'm not sure how I'm going to clean it. I really want to sand blast it, but it is very messy. I might do it anyways. I am going to stainless shot blast the parts that I am keeping. Most of the suspension will be replaced."
      Its not the first time Jeff has missed his period.
        Unless you meant:
        I'll go with the ladder.
        I always thought acid dipping was where it is at for a restoration but I learned out that it takes away all of the inner rust proofing so it ends up to be a lot of work to do it right.  Spraying that wax stuff in the inner frame rails, sealing the seams/welds(?).  There probably is more to do than I know about.
        • JeffJ
          JeffJ
          Jeff
          well can't have to many periods going on at the same time now can you?
          1976 530i e12
          1990 325ix e30
          1992 325i e36
          1995 740il e38
          2001 330xi e46
          ^More to come :)
          • JeffJ
            JeffJ
            Jeff
            there are many ways to seal the inner frame rails. i usually use a piece of 1/4" brake line and an old paint gum to spray the inner rail with rubber coating. help at 120psi does wonders!!!
             dropped the front subframe
            also finished stripping out the engine bay finally.
            1976 530i e12
            1990 325ix e30
            1992 325i e36
            1995 740il e38
            2001 330xi e46
            ^More to come :)
              How are those bolts coming off with the rust?
              With all the old bimmers I've had, all e30s, rusty bolts were never a problem.  I can't say the same about my xj jeeps.  I probably broke every body bolt on those...
                superior German metallurgy,   no joke.
                • JeffJ
                  JeffJ
                  Jeff
                  Surprisingly very easy only a couple bolts broke but they where very small
                  1976 530i e12
                  1990 325ix e30
                  1992 325i e36
                  1995 740il e38
                  2001 330xi e46
                  ^More to come :)
                    It's true, the only bolts I have ever broken on my e36 were manifold to downpipe studs and the bolts for the rear trailing arm camber adjustment.  (Those ones suck bad to drill out)
                    • JeffJ
                      JeffJ
                      Jeff
                      I shall update soon I'm not dead just busy
                      1976 530i e12
                      1990 325ix e30
                      1992 325i e36
                      1995 740il e38
                      2001 330xi e46
                      ^More to come :)
                        Glad I texted you yesterday Jeff=)
                        • JeffJ
                          JeffJ
                          Jeff
                          Me too I miss the forums work has been busy. We'll work and making stuff
                          1976 530i e12
                          1990 325ix e30
                          1992 325i e36
                          1995 740il e38
                          2001 330xi e46
                          ^More to come :)
                            Don't worry Jeff
                            This forum is like a creed song.
                            We are always here with arms wide open
