  4. E21 project thread
E21 project thread
    Look at those 6" charge pipes and 12" thick intercooler.
    And you accuse me of overdoing it.
      Took off today and got to work on the car some more. Finished powdercoating the hood hinges.
      Connected megasquirt to the laptop and tested a few things to see if wiring was correct. So far everything seems to check out fine which is a relief.
      Snugged down the intake manifold.
      Bolted down the throttle body.
      Ran the fuel hose from the stock hard lines to the fuel rail.
      Removed the dented up front US valance.
      Old US valance compared to the euro valance I will be modifying (Thanks again Kyle)
      Mock fit the oil cooler and ran the lines into engine bay.
      Started working on the custom oil cooler mounts and thats where I stopped. I will be doing more work tomorrow as well.
        You got a lot done!
        • RamRod E28R
          RamRod E28R
          RamRod E28
          getting closer to burnouts! now to get bfinley's ass in gear to get his e21 done for some epic tandom e21 burnouts/ragedrifts!
          1988 BMW 528e - Need parts?
          1996 Mazda Miata (SOLD!!!)
          1996 BMW 325i (Donor car)
            bfinley
            Excuse me sir my ass is firmly in gear. Im eaiting on parts
            Sent from my SCH-R830 using Tapatalk
              Doesn't feel like I accomplished much but took a lot of time. 😕 Finished up the lower oil cooler mounts and got them tapped and jb welded on. We'll see how it holds. y2asa4ad.jpg
              Then I went ahead and made the top oil cooler mounts as well out of flat stock aluminum. udy3avy7.jpg
              I also bolted the front euro bumper to the euro valance with two longer carriage bolts (thanks Kyle for the trick). Since I have to modify it all to for the group 2 flares, it works perfectly.
              I then noticed I wanted the two air duct holes in the alpina spoiler to be open, so I cut the lip off the valence. 9anamate.jpg
              Much better!
                Powdercoated the upper oil cooler mounts
                Degreased, rust blasted & KBS coated the front radiator support
                Cut down the braided lines to correct lengths and mounted/installed oil cooler
                  the new to me 2.0L to up my displacement and lower my compression. Thanks again Ben (bfinley)!
                  • The Full BananaT
                    The Full BananaT
                    The Full Banana
                    is my brain broken or is that mounted sideways on the engine stand?
                    keep at it!
                      It sure is mounted sideways on the engine stand :P
                        bfinley
                        Glad to help ! Thanks for the decals
                          bfinley
                          http://dtmfiberwerkz.com/access/motorsports-style-rear-bumper-p-425.html
                            Looks decent, but that price, yikes! Thanks for the heads up tho.
                              Been working on getting the charge piping cut/ground/welded since realizing that the e30 ellipsoids with HIDs I am running interfere with the SMIC placement. For now I will run it without an IC like I have been in the past. Until I figure something else out that is. Been a slow process which really makes me wish I had a welder and the skills to do it myself. Oh well.
                                Got the welded up charge piping back the other day.
                                The pieces that were made back in the 80s turned out to be mild steel instead of aluminum, so I had to get a coat of paint or powdercoat on them to prevent rusting. So I opted to paint all the piping in cast iron gray color.
                                I love the color and it goes with the old school theme of the car. Looks brownish gray in the sun but kind of army green in the shade. I still dig! I got it all mounted up and snugged down. Along with the IAC to intake hose as well.
                                Just need to hook a few more things up and fill with fluids and I should he able to try starting it. Soon!
                                  im so giddy
                                    Got my new +0.50mm pistons in the mail today for the 2.0 block rebuild side project.
                                    • andyhundleyA
                                      andyhundleyA
                                      andyhundley
                                      I'm excited to ride in this!
                                      • RamRod E28R
                                        RamRod E28R
                                        RamRod E28
                                        I want that charge pipe color for my engine bay that looks so good!
                                          Duplicolor high temp Cast Iron Gray.
                                          Great color
