  4. TehRaydarlover's AWD lover
156 Posts 15 Posters 0 Views 1 Watching
    Look great, Any idea what happened to the intermediate shaft bearing?  Did it run without oil?
    And what is the toothed ring for on the flywheel end of the crank?
    How far does the splined drive shaft end extend into the drive shaft?  If it an inch or more and it has to be pressed in I wouldn't worry about runout/balancing issues as long as they weld in alternating spots until it is tacked thoroughly.
    • TehRaydarloverT
      TehRaydarloverT
      TehRaydarlover
      Thanks,
      I have no idea what happened to the bearing, I bought just the short block and never ran it. Looks like it wasn't getting any oil for some reason, but the rest of the engine looked fine. I'm thinking the oil passage got plugged somehow. The inner bearing is in good shape so you would think if the engine was run with no oil it would be messed up too. Makes me think it was a local problem.
      I believe the toothed ring is for the s52 crank position sensor. Not sure if its going to interfere in the m20. It unbolts from the crank but that might mess with the balance of the crank.
      Yeah I would think that it would be fine. I forget how far it is pressed in, I think a good 1-1.5". This is the setup someone else did to weld it:
      101427010200930812546806414518120n.jp
        Interesting, I was not aware that the obd2 engines had a cps on the back of the crank, m/s50 does not have that.  Obd1 has it on the harmonic balancer.
        • TehRaydarloverT
          TehRaydarloverT
          TehRaydarlover
          Yeah Idk, real oem says its an "impulse sending wheel"  I assume for the cps.
            The S52's have that on the driver's side of the engine block 3in or so from the back of the block.
            Great work!  I'd go turbo but get a correct size/fan for a horsepower powerband and not a torquey one.  Todd (TCD on here) helped me with that and he did a perfect job looking out for the path I wanted to take.  I didn't for for the high torque to try to save my rear suspension / drivetrain.
            I think I know the area where you live and I always try to drop it down to 2nd and open her up when I see your car parked.  #livinguptomyname
            • TehRaydarloverT
              TehRaydarloverT
              TehRaydarlover
              Thanks.
              Yeah, I have very little knowledge on sizing turbochargers, my friend told me to read Maximum Boost by Corky Bell.
              Ha whenever I hear someone with a loud exhaust drive by I'm usually at the window like,"WHERE ARE YOU"
              I'm about a block off Brady St. if you ever see me working on my car you should stop by.
                I know where you're at. I didn't want to come off like a total stalker. You'll hear me around 7:30am tomorrow! The M3 will be your alarm clock.
                • TehRaydarloverT
                  TehRaydarloverT
                  TehRaydarlover
                  Ha you'll have to give her the beans! I'm a pretty heavy sleeper.
                    T-minus 47 minutes
                      It was more like 7:15. I couldn't give it to the full potential due to the beans being cold.
                        Hit the sirens
                        • TehRaydarloverT
                          TehRaydarloverT
                          TehRaydarlover
                          Me waking up this morning
                          Expectation:
                          Reality:
                          The neighbors probably wouldn't agree with me that being woken by the god of hellfire would have been more enjoyable that the samsung song of death that is my alarm.
                            If you are going to do custom pistons, why not throw the extra 700$ or less for a set of rods?
                            Do the megasquirt DIYPNP! Great option for e30's.
                            • TehRaydarloverT
                              TehRaydarloverT
                              TehRaydarlover
                              hmm for some reason I was under the assumption that s52 rods were forged? Wanted to use them because they are the lightest/strongest(?) 135mm stock rods. I guess some forged h-beams or something wouldn't hurt, just money. With the s52 crank you need custom pistons.
                              Yeah I was planning on doing the DIYPNP. I just need to do the research on what I want to include as far as extras and how to do it. Then maybe get a little help from someone with the setup and building of it haha.
                                I'm running K1 rods.
                                  s52 rods are one of the best to use! yes!
                                  But because of the custom pistons which of course you need, I was saying why not just do the whole shebang? Not much more expensive at that level.
                                  I actually take that back. If you are running this kind of build, why not go all out and do MS3x? Not much more expensive and I believe its worth it. You can do coil on plug then(with cam sync) and also fully sequential fuel. And tons of other goodies! If you need guidance on what to buy for megasquirt, let me know.
                                  • TehRaydarloverT
                                    TehRaydarloverT
                                    TehRaydarlover
                                    Bit of an update, I noticed that both of my drivers side front cv boots were torn so I decided it was time to swap in the axles I rebuild a while ago. One thing kinda led to another and I ended up replacing a lot of parts.
                                    Got every thing pulled apart. Out with the old and in with the new
                                    Took me two long days to get everything disassembled... break time, off to Europe :)
                                    5 days in Paris, France
                                    4 day in Luzern, Switzerland
                                    Saw my first touring and it was an ix :') thing was unbelievable must have just been restored. You could perform surgery on the underside of this thing. I tried knocking on the door but no one was home :(
                                    3 days in Salzburg, Austria
                                    Then finally 3 days in Munich, Germany
                                    Picked up some euro goodies at a junkyard in Munich
                                    THEN THE BMW WELT AND MUSEUM!!!
                                    Another 325ix touring!!
                                    neat
                                    Cleanest m20 ever
                                    Z1
                                    2002
                                    • TehRaydarloverT
                                      TehRaydarloverT
                                      TehRaydarlover
                                      The ///M division, I was the first person in the museum because I had to catch my plane to go home, not sure if you are suppose to go up on the platform the cars are on but no one was around so I did haha.
                                      Flying over Greenland
                                      Enough fun back to Minnesota
                                      Cleaning my smileys
                                      Got everything ready to be put back together when I noticed a bit of a problem. Broken subframe bolt 😢 Funny I didn't even notice it broke until I came back from vacation and was ready to put it all back together. The bolt stayed in the subframe when it came down.
                                      I bought an extractor and tried to get the broken subframe bolt out but nothing would work. Soaked it in penetrating oil for 3 days, tried heating it with a torch, nothing... ended up drilling it out and retapping the hole. Put the subframe back on and the new bolt fit perfectly! Thank God! Such a relief seeing I had to drill it out with a hand drill.
                                      Got the new smileys installed and the city lights all wired up after dealing with finding a break in the passengers side wiring.
                                      Got the new front driveshaft all welded and painted
                                      So after all the work I now have rebuilt front axles, new control arms with m3 offset bushings, motor mounts, power steering rack, pump, and reservoir, upper strut mounts, all new belts, euro smileys, German check panel, and new fluids in the front/rear diffs transmission, and transfer case. I also tracked down the broken wire for my oil level sensor so now I have no lights on the dash or check panel! yay :)
                                      As a reward for all the work I went to a car show and found a 1957 Isetta! So cool!
                                          Can I triple like that post!?!
