  4. e36 Front Caliper: Assembly Issue
14 Posts 4 Posters 0 Views 1 Watching
    I am having an issue with one of my front calipers that I am rebuilding.
    I cannot get the piston to slide into the bore. I can get it to slide in when I dry fit the parts, install just the seal (no dust boot), or install just the dust boot (no seal). If I install the seal and the dust boot, the piston will not slide into the bore. It seems to be getting hung up on something.
    I took the piston off again this morning to see nothing that would cause it to hang up (I have done this more times than I would like to think). There is light corrosion in the rear half of the bore but it doesn't cause any hang-ups during dry fitting.
    I am thinking that I should still remove that using 600 grit emery cloth.
    My other front caliper went together very easily and so did both of my rears. I am confused as to what is causing the hold-up. Any ideas?
      What are you using to lubricate the seals?
        Caliper assembly lube. It worked excellent on the other three calipers=) I even used a shit ton to see if it would help and that didn't work at all either.
        Edit: I just tried fitting the piston with just the inner seal again. Now that isn't working. It seems like the o-ring won't allow it to pass through. I took it out and set it around the piston to see if it was super tight or what the issue was. The o-ring actually seems to be a good bit larger than the piston (approximately 1/32 gap between the two). Could this be a defective o-ring or could it be swelling from the caliper assembly lube? I am not sure why it may have worked with just the seal before but now it doesn't. I can order another rebuild kit but want to make sure that this o-ring isn't supposed to be like this=)
        • merlM
          merlM
          merl
          I had one that was difficult to assemble as well ... It just took time and influence and it did finally go together.
            I would recommend brute force at this point.
              I tried multiple brute force methods and it seemed to lodge the piston without driving it in. haha Anyone want to give a hand at assembling this one? I have been trying not to ruin the powder coat as well.
                So I took scotchbrite and cleaned up the inner bore. I then lubricated everything again and tried to reassemble the caliper. It is still a no go. Now to try the piston in the freezer
                  Still SOL=/
                    Would anyone be interested in looking at this at the e30 picnic this weekend? It would be nice to be done with the calipers
                        Just bring it with, I'm sure somebody can look at it.
                          Lol Was planning on it=P
                          • I
                            I
                            industrialsized
                            if no one takes car of you txt me and ill get it worked out for you
                              Thanks Dustin =P I am just confused as to why only one of the four is being a pain lol
