<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[e36 Front Caliper: Assembly Issue]]></title><description><![CDATA[<p dir="auto">I am having an issue with one of my front calipers that I am rebuilding.</p>
<p dir="auto">I cannot get the piston to slide into the bore. I can get it to slide in when I dry fit the parts, install just the seal (no dust boot), or install just the dust boot (no seal). If I install the seal and the dust boot, the piston will not slide into the bore. It seems to be getting hung up on something.</p>
<p dir="auto">I took the piston off again this morning to see nothing that would cause it to hang up (I have done this more times than I would like to think). There is light corrosion in the rear half of the bore but it doesn't cause any hang-ups during dry fitting.</p>
<p dir="auto">I am thinking that I should still remove that using 600 grit emery cloth.</p>
<p dir="auto">My other front caliper went together very easily and so did both of my rears. I am confused as to what is causing the hold-up. Any ideas?</p>
]]></description><link>https://wibimmers.com/topic/2585/e36-front-caliper-assembly-issue</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:46:23 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/2585.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 18 Apr 2014 11:37:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to e36 Front Caliper: Assembly Issue on Fri, 09 May 2014 07:50:05 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Dustin =P I am just confused as to why only one of the four is being a pain lol</p>
]]></description><link>https://wibimmers.com/post/40710</link><guid isPermaLink="true">https://wibimmers.com/post/40710</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Fri, 09 May 2014 07:50:05 GMT</pubDate></item><item><title><![CDATA[Reply to e36 Front Caliper: Assembly Issue on Fri, 09 May 2014 06:52:28 GMT]]></title><description><![CDATA[<p dir="auto">if no one takes car of you txt me and ill get it worked out for you</p>
]]></description><link>https://wibimmers.com/post/40707</link><guid isPermaLink="true">https://wibimmers.com/post/40707</guid><dc:creator><![CDATA[industrialsized]]></dc:creator><pubDate>Fri, 09 May 2014 06:52:28 GMT</pubDate></item><item><title><![CDATA[Reply to e36 Front Caliper: Assembly Issue on Thu, 08 May 2014 23:49:31 GMT]]></title><description><![CDATA[<p dir="auto">Lol Was planning on it=P</p>
]]></description><link>https://wibimmers.com/post/40689</link><guid isPermaLink="true">https://wibimmers.com/post/40689</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Thu, 08 May 2014 23:49:31 GMT</pubDate></item><item><title><![CDATA[Reply to e36 Front Caliper: Assembly Issue on Thu, 08 May 2014 21:42:12 GMT]]></title><description><![CDATA[<p dir="auto">Just bring it with, I'm sure somebody can look at it.</p>
]]></description><link>https://wibimmers.com/post/40676</link><guid isPermaLink="true">https://wibimmers.com/post/40676</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Thu, 08 May 2014 21:42:12 GMT</pubDate></item><item><title><![CDATA[Reply to e36 Front Caliper: Assembly Issue on Thu, 08 May 2014 21:30:45 GMT]]></title><description><![CDATA[<p dir="auto">?</p>
]]></description><link>https://wibimmers.com/post/40675</link><guid isPermaLink="true">https://wibimmers.com/post/40675</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Thu, 08 May 2014 21:30:45 GMT</pubDate></item><item><title><![CDATA[Reply to e36 Front Caliper: Assembly Issue on Wed, 07 May 2014 17:26:14 GMT]]></title><description><![CDATA[<p dir="auto">Would anyone be interested in looking at this at the e30 picnic this weekend? It would be nice to be done with the calipers</p>
]]></description><link>https://wibimmers.com/post/40522</link><guid isPermaLink="true">https://wibimmers.com/post/40522</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Wed, 07 May 2014 17:26:14 GMT</pubDate></item><item><title><![CDATA[Reply to e36 Front Caliper: Assembly Issue on Tue, 22 Apr 2014 22:36:15 GMT]]></title><description><![CDATA[<p dir="auto">Still SOL=/</p>
]]></description><link>https://wibimmers.com/post/39392</link><guid isPermaLink="true">https://wibimmers.com/post/39392</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Tue, 22 Apr 2014 22:36:15 GMT</pubDate></item><item><title><![CDATA[Reply to e36 Front Caliper: Assembly Issue on Fri, 18 Apr 2014 22:01:21 GMT]]></title><description><![CDATA[<p dir="auto">So I took scotchbrite and cleaned up the inner bore. I then lubricated everything again and tried to reassemble the caliper. It is still a no go. Now to try the piston in the freezer</p>
]]></description><link>https://wibimmers.com/post/39221</link><guid isPermaLink="true">https://wibimmers.com/post/39221</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Fri, 18 Apr 2014 22:01:21 GMT</pubDate></item><item><title><![CDATA[Reply to e36 Front Caliper: Assembly Issue on Fri, 18 Apr 2014 13:29:15 GMT]]></title><description><![CDATA[<p dir="auto">I tried multiple brute force methods and it seemed to lodge the piston without driving it in. haha Anyone want to give a hand at assembling this one? I have been trying not to ruin the powder coat as well.</p>
]]></description><link>https://wibimmers.com/post/39202</link><guid isPermaLink="true">https://wibimmers.com/post/39202</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Fri, 18 Apr 2014 13:29:15 GMT</pubDate></item><item><title><![CDATA[Reply to e36 Front Caliper: Assembly Issue on Fri, 18 Apr 2014 13:03:10 GMT]]></title><description><![CDATA[<p dir="auto">I would recommend brute force at this point.</p>
]]></description><link>https://wibimmers.com/post/39196</link><guid isPermaLink="true">https://wibimmers.com/post/39196</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Fri, 18 Apr 2014 13:03:10 GMT</pubDate></item><item><title><![CDATA[Reply to e36 Front Caliper: Assembly Issue on Fri, 18 Apr 2014 12:55:47 GMT]]></title><description><![CDATA[<p dir="auto">I had one that was difficult to assemble as well ... It just took time and influence and it did finally go together.</p>
]]></description><link>https://wibimmers.com/post/39194</link><guid isPermaLink="true">https://wibimmers.com/post/39194</guid><dc:creator><![CDATA[merl]]></dc:creator><pubDate>Fri, 18 Apr 2014 12:55:47 GMT</pubDate></item><item><title><![CDATA[Reply to e36 Front Caliper: Assembly Issue on Fri, 18 Apr 2014 12:13:58 GMT]]></title><description><![CDATA[<p dir="auto">Caliper assembly lube. It worked excellent on the other three calipers=) I even used a shit ton to see if it would help and that didn't work at all either. </p>
<p dir="auto">Edit: I just tried fitting the piston with just the inner seal again. Now that isn't working. It seems like the o-ring won't allow it to pass through. I took it out and set it around the piston to see if it was super tight or what the issue was. The o-ring actually seems to be a good bit larger than the piston (approximately 1/32 gap between the two). Could this be a defective o-ring or could it be swelling from the caliper assembly lube? I am not sure why it may have worked with just the seal before but now it doesn't. I can order another rebuild kit but want to make sure that this o-ring isn't supposed to be like this=)</p>
]]></description><link>https://wibimmers.com/post/39191</link><guid isPermaLink="true">https://wibimmers.com/post/39191</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Fri, 18 Apr 2014 12:13:58 GMT</pubDate></item><item><title><![CDATA[Reply to e36 Front Caliper: Assembly Issue on Fri, 18 Apr 2014 12:04:49 GMT]]></title><description><![CDATA[<p dir="auto">What are you using to lubricate the seals?</p>
]]></description><link>https://wibimmers.com/post/39189</link><guid isPermaLink="true">https://wibimmers.com/post/39189</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Fri, 18 Apr 2014 12:04:49 GMT</pubDate></item></channel></rss>
