  4. New ride! 89 e30 vert
summertime rage
141 Posts 18 Posters 1.6k Views 3 Watching
  • 6670charger6
    6670charger6
    6670charger
    I have the same con list, except that mine goes forward too.
    Appleton, WI
      Sounds good on pulling the engine, I will be replacing seals and all that jazz so that will be easier with engine out as well.  Too bad the rad support doesn't just come off of the e30's the same as e36's or does it?  Hmm I will have to do some thinking on the bushing choice, I have UUC red RTAB's in my e36 and they squeak because I did not use the correct lube.  What lube have others used and does it have to reapplied after a few years or just at install?
        E30 rad support is not removable. You need a load leveler for the engine hoist and the front of the car has to be on tall enough jackstands for the tail end of the transmission to avoid the ground.
        Copper grease is what I would use for poly, and lots of it.
          Bs! Totally removable :) I removed mine! Makes for awesome engine mock ups haha
            Something like this.
              Stopped at the storage unit to grab the coolant bleed screw for bfraser and the poor thing looks so lonely in there.
                We be SWOPPIN!!!
                  Im sure its the g260 swop but if its an m50 swop then i dont know what we will do
                  Sent from my
                  • RamRod E28R
                    RamRod E28R
                    RamRod E28
                    Snap u just never know what us boys of the southwest are up...
                    1988 BMW 528e - Need parts?
                    1996 Mazda Miata (SOLD!!!)
                    1996 BMW 325i (Donor car)
                      Haha no m50 swap, Mike came over and we got it from the storage unit into the garage driving in reverse the whole way.
                      Goodbye to you
                      and you
                      and you Mr kickdown cable
                      Got it up on stands and I drained fluids while Mike took out the shifter
                      Exhaust removed, the muffler wasn't attached to the pipes anymore so I will have to fix that up.
                      Next up, pull driveshaft, and order a few things.
                        I still have my OE muffler if you are looking for one, but id rather spend $80 and get a Magnaflow anyways
                          Can't hear dat OE!!  I want some m20 rumble.
                            bfinley
                            So Sexy!
                              bfinley
                              John,
                              Thanks for letting Damian and I stop by yesterday. The 'vert is even prettier in person.
                              As we were leaving Damian goes "your friends really nice but I kind of hate him right now" he spent the rest of the day about how you got a clean e30 vert for cheap monies
                              • RamRod E28R
                                RamRod E28R
                                RamRod E28
                                you need these wheels for your e30
                                  I like those, they remind me of Alpina wheels, what are they?
                                  • RamRod E28R
                                    RamRod E28R
                                    RamRod E28
                                    snap should know they look oem to me
                                      He doesn't know everything! They aren't OEM E30 wheels as style 32's are 18 spoke and didn't come that small. My best guess was Hartge but those are 12 spoked and I genuine hartge's are 11 spoke.
                                        Got some work done yesterday.  Pulled the drive shaft and found this.
                                        Anybody here seen the cam belt ride way to the front and rub on the covers?
                                        Appears this has been worked on before, and they forgot to put something back...
                                        I love you late m20 and your plug in fuel injector harness goodness also it's way better with both fuel lines at the front of the rail.
                                        Engine is grimy but looks great
                                        Coolant has been flushed regularly, this is the best I have seen inside, no rust or scale inside the block or head.
                                        Got the trans out, never pulled an auto before so I dumped all the fluid from the torque converter out, caught half of it in a bucket luckily but still made a mess.
                                        Goodbye evil slushbox!
                                        Also this is getting expensive, just made a $625 order from Pelican to hopefully have everything I need.
                                        WTB cap and rotor, Rowley, message me back.
                                        Little bracket thing for the back of the shift linkage: wasn't going to pay the 50 bucks for a new one, somebody has to have one.
                                        PM me asap if you have any of this.
                                          Ah, yes,  MiM 1900's
                                          MiM 1900's
                                          They are MiM 1900's
                                          Very true! but I do know how to multiquote.
