pistonse30
    9:00AM this Friday I'll be on the dyno at Late Model Throttle!! #itbetternotsnow
      videosvideosvideosvideos
        I'll get the gopro all set up.
          A very safe and strong 442whp. Not too happy but there is room for improvement and my A/F is consistent across the rpms which was my main goal with this dyno run. It looks like the TRM tune is in the 11-12s and will be safe to crank up the boost. My 1st dyno run I was below 10s due to vacuum leaks so this is a good thing.
          I'm at 13psi. What do you guys think I should do to up the boost? Spring by spring and inch my way up or get a boost controller? Taking the wastegate out is a pain in the butt.
            442whp run
            http://www.flickr.com/photos/70254549@N06/12837574875/
            441whp run
            http://www.flickr.com/photos/70254549@N06/12837662095/
              AFRs are nice and smooth, assuming the dyno doesnt have a crazy smoothing factor in place.
              Do you have a compressor map for your turbo? otherwise what are the specs and I will try to find one
                440whp? Yea I would be a bit disappointed. Use a wastegate spring that's the lowest boost you want and use an electric boost controller on top of that for mad boostages. Aren't you running a 40r? Man I'm not that impressed. Turn up the boost and wake it up! You aren't even getting into the good part :)
                This thing is a beast and I can't wait to see it in person!
                  I have one a couple of pages back.
                  Rowleym said:
                  440whp? Yea I would be a bit disappointed. Use a wastegate spring that's the lowest boost you want and use an electric boost controller on top of that for mad boostages. Aren't you running a 40r? Man I'm not that impressed. Turn up the boost and wake it up! You aren't even getting into the good part :) This thing is a beast and I can't wait to see it in person!
                  I will turn it up for sure.  I might wait until this weather warms up.  There are times that I spin in 5th gear with the cold and salt on the road.
                    I'm not too good with dyno charts yet but aren't the HP and Torque lines supposed to intersect at a consistent spot at a lower rpm?
                      Interesting.....  call them up and ask why they dont intersect at 5252 RPM.
                      EDIT: It looks like the Y-axis on the left and right sides is unequal. If you equated them, it would probably intersect at 5252
                        I guess the computer auto-scales the graph to make it more "readable".
                          Just watched the videos
                          Goodness, that thing squats down pretty hard on the rollers there  O__O
                          Everyone knows it and has said it, but you have put together a pretty serious machine!
                          also
                          your coat reminded me of this.
                          Thanks for the footage!!
                            It's cold out there, son!  :D
                            Thanks, Snap!  Maybe next winter I'll upgrade the fuel system and go megasquirt.  I'll be calling you hourly when I cross that bridge.
                              I'll wrap this day up with a couple of words:
                              From my last dyno run to today I basically got my sparkplugs right, added a full 3in exhaust, fixed a couple vacuum leaks and added CCV.  I thought the vacuum leaks would hinder HP more than it did or maybe the exhaust is way more restrictive now than it was coming straight out of the hood.  In the end I'm in a good spot with only more to gain.  Now who wants to pull out my wastegate for me??
                                The face of 442whp <<
                                  This thing is sweet as gold shoes!
                                    E85 surge tank setup and megasquirt go go go go!!!!!!!
                                      It just loaded for me... But in post 443. That second pic of the front of the car. Is too freakin' cool.
                                        I had the good camera out today!  Thanks!
                                          List of things I need.
                                          -Fuel pressure regulator adapter for a M50.
                                          -PLX Devices power plug for the wideband.
                                          -Bigger I.D. vacuum line for my wastegate and the fittings to go with it.
                                          The vacuum line should raise the boost up but I don't want to do that until I get my wideband working (again). Then I can dial it in with the FPR.
                                          I'm also going to have Kummrow fix my oil leak. Messed my arm up and wrenching probably shouldn't be happening.
