  4. Savin Big Money Project Thread
should just dri
178 Posts 23 Posters 3.3k Views 3 Watching
    Tell me about it=)
    • e92boostE
      e92boostE
      e92boost
      Nice work man.
      Ben H.
        She will be 2 in May, her hair is so long that she looks older, it is fun when she comes out to "help" me.  I hope that doesn't change when she gets older.
        The head was a clean reman one when I put it on, that's after 5yrs/45k.  I use Royal Purple HPS 5w-30 changed about every 10k, with a filter change about every 5k.
        Edit: HPS not XPS
        Holy hell I change the filter and oil(t6 synthetic) every 3k about.
        • RamRod E28R
          RamRod E28R
          RamRod E28
          I just roll with mobil 1 full synthetic every 5k and change and use mann filters
          1988 BMW 528e - Need parts?
          1996 Mazda Miata (SOLD!!!)
          1996 BMW 325i (Donor car)
            This is now the oil change interval thread.
            5000 miles on Valvoline synthetic blend with Wix filters
              ^ abort thread.
              • RamRod E28R
                RamRod E28R
                RamRod E28
                It seems time for jc43089 to grave our presence with some new pics
                  I will be off Thursday - Sunday this week, I hope to get all of the undercoating off this week, the bay is all cleaned up and some of the bottom so far.
                    finally read through this. Ill be doing just about the same thing in a week or two here.. nice to have something to look over though. Good job man.
                      Stripped a bunch of stuff to be powder coated.  Still need to get bushings pressed out.
                      Welded in front sub frame reinforcements.  This side was torn through around the mount bolt that's why it's kinda messy, it's solid for sure now.
                      And for the rear sway bar.
                        Burn them outta there!
                          Passenger side floor is undercoating free.  Arms hurt so bad.
                            Half done on driver side.  Someone come do my body work, and I will build you an engine!
                              bfinley
                              I think we could arrange something. You'll have to come out to the shop and see the e21 after take everything out.
                                gasp0
                                hi,
                                did you use intake sprocket from m54 or m52? on intake side
                                  gasp0 said:
                                  hi,
                                  I will be using the original m50 sprocket.
                                  Rear sub frame mount reinforcements are installed, Started on RTAB pocket reinforcements.  The undercoating has been a nightmare.  Mike came over to help some and it is too slow with the current method.  I am going to make a Harbor Freight run and get a sandblaster to give that a try, even if it doesn't work it will be handy to have for other projects.  Tried zip strip and it doesn't even soften it, not sure what else to do.
                                  Moral of the story, just buy a car from the south.
                                    You nailed it.
                                    Less time messing around with rust repair and stubborn/broken bolts, more time improving things, more time enjoying the car.
                                    • RamRod E28R
                                      RamRod E28R
                                      RamRod E28
                                      Yeah but getting a car from the south means u have to trust photos and the cost of getting it too
                                        I bought my current 528e based off two crappy cell phone pics, so it was a good surprise to see how good a shape it was when I picked it up! While its nice for suspension work, body work has to be done on almost any car this age. Also fixing things yourself means you know your car better and won't have any surprises down the road.
                                          My car is a Florida car (Not the salt spray part) and it is clean as a whistle underneath, the only problem is that anything made of plastic must be handled with more care than an ancient manuscript...
                                          On a more relevant note, can't wait to see the progress!
