    I have a new tensioner since the m42 one exploded when I removed it. lol I will get it in this weekend and see what is up. So I will know if it is timed right if it spins over without hitting anything correct? I just want to make sure I am getting this right.
      Yep, you are way over thinking it, it's super easy.
        I feel much better about this now=) I love this forum=D
          Even the vanos timing on the m50/52 is really easy if you think about what you are doing.  I have done it several times and never even use the cam locks, a straightedge works great the only tool you need is the threaded tool for the chain tensioner.
            Yea Ive taken apart a running m20 that was two teeth off and no problems(ran like poopy). There is some slack before valve/piston interferance.
            • L
              L
              Laishes
              What do you mean by teeth? M20s utilize a timing belt rather than a timing chain like their m30 counterparts?
                ^the teeth/lugs on the belt.
                  Hahahah technicalities technicalities.
                  You know what I meant dammit! :)
                  • L
                    L
                    Laishes
                    Rowleym said:
                    Hahahah technicalities technicalities. You know what I meant dammit! :)
                    Just giving you a hard time ;)
                    Gotta keep em' on there toes!
                      It was awesome seeing this in person last weekend Earl! Good to know that the timing should be down :)
                        Thanks Chris=) It was nice having you out
                          It seems I am having a hard time working with Adams Rotors on getting the right ones made. For some reason, Centric doesn't show that Compacts had the option for vented front rotors unless it was a 98 or 99. Adams Rotors goes by what Centric says instead of the RealOem diagram that I supplied.
                          I just want to recoup some of the cost so I can get the proper fronts. Get someone to buy these please:
                          http://www.wibimmers.com/board/index.php?/topic/2398-feeler-e36-front-rotors/
                            Are the Adams rotors made from Centric blanks?
                              From what I can gather that is correct. They are the largest OE supplier of rotors and somehow do not know that compacts before 1998 had the option  for either solid or vented fronts. It seems I am getting parts of the blame for that for who knows what reason. Centric only shows few I's and then IS's got vented fronts that are the same diameter as mine.
                                Tell them to take them back, too bad, so sad for them.  It's not like they are interchangeable, I imagine the calipers are different to accommodate the quite different thickness between vented and non vented.
                                  They're definitely very different thickness wise. I only see one caliper option so I would imagine you get pads that are thicker to take up the slack.
                                    That seems very strange, unless the steel backing plate was thicker the pad would wear until the ears on the pad disengage from the grooves in the caliper and the pads would come out.
                                    • andyhundleyA
                                      andyhundleyA
                                      andyhundley
                                        I'm not sure. I am very confused.
                                        Thanks for the pics Andy. I didnt even know you took them=)
                                          Will the 98/99 vented rotors fit your car? I'd keep fighting with them especially since you specified vented in the first place. Not your fault their catalog was wrong and adam's based their decision on that.
