pistonse30
    I had a leak from the same(ish) spot! You really can't move it much, need to unbolt it from the head (3 small torx) and you need to use a wobble extension to get under the timing chain without taking it out, 1/4" drive is required for that one. Take out the front oil pan bolts, but loosen the rest a turn or two and now it should be separated enough! Was a pain to do, but not as bad as expected. Sent from my XT907 using Tapatalk 2
    Thanks for the reassurance!  I'll probably run it with the leak for a bit until I break it down again.
      That engine deserves a quality air filter
        I'll work on that. I have a k&n itching to be installed.
          Watch your oil/coolant closely. That front cover has oil and coolant running in it, those don't like mixing
            That tiny little bit of oil is just for anti rust purposes, just giver!
              I'll get in the garage once this cold snap gets outta here!
              After I fix this leak I'm heading straight to the dyno.
                dont fix the leak, then we all wont be able to follow you there.
                  Gift from the girlfriend!!!
                    Please tell me you have a jumpsuit to match the shoes!
                      Oh God do I wish!!!
                        In what situation does one wear shoes like that?
                          When one drives a s52 turbo e30 with gold goodies 😃
                            If there is a fear of getting lost or when stunting hard is the only remedy for a situation.
                              Perfect for Wheelies
                                Thought you needed to know the 2015 plate registration stickers are in fact GOLD!!
                                  I don't think I need to register. But I do have a sticker guy...
                                    Brewers plates get renewed anually.
                                    H3 GON3!
                                    • milwaukeeandyM
                                      milwaukeeandyM
                                      milwaukeeandy
                                      i can't wait to see this car in person and bother you for a ride in it
                                        I got you! Haha. I can't wait to drive!!
                                          Oil leak should be gone soon.
