pistonse30
    oh gosh why  O__O
      oh gosh why  O__O
      I just popped the intake manifold off to get at the heater core hoses easily.
      I'm headed back into the garage to start putting everything back together after I eat.
        thank goodness.
          Billy doing work!
          All buttoned up!  Radiator/Coolant/Oil tomorrow if work doesn't get in the way.
          Snap, see the intercooler mount?
          I'm going to run cheap oil and sea foam to Billy's shop on 1st St. then get a new filter and royal purple in there.
          I picked up some new covers from Gluten Parts.  So nice to see the new parts sticker!!
            So I got it running again and I narrowed down the leak to the lower cover towards the top. Ugh.
            #processofelimination
            I have Teflon and an o-ring on the tensioner. So I don't think that's where the leak is coming from.
            I'll see if anything is loose then if it is still leaking I'll have to pop off the valve cover and lower cover then try to get enough space in between the block and cover to ooze some rtv in there without having to take off The Bolt of Jesus.
              I had a leak from the same(ish) spot!
              You really can't move it much, need to unbolt it from the head (3 small torx) and you need to use a wobble extension to get under the timing chain without taking it out, 1/4" drive is required for that one.
              Take out the front oil pan bolts, but loosen the rest a turn or two and now it should be separated enough!
              Was a pain to do, but not as bad as expected.
                I had a leak from the same(ish) spot! You really can't move it much, need to unbolt it from the head (3 small torx) and you need to use a wobble extension to get under the timing chain without taking it out, 1/4" drive is required for that one. Take out the front oil pan bolts, but loosen the rest a turn or two and now it should be separated enough! Was a pain to do, but not as bad as expected. Sent from my XT907 using Tapatalk 2
                Thanks for the reassurance!  I'll probably run it with the leak for a bit until I break it down again.
                  That engine deserves a quality air filter
                    I'll work on that. I have a k&n itching to be installed.
                      Watch your oil/coolant closely. That front cover has oil and coolant running in it, those don't like mixing
                        That tiny little bit of oil is just for anti rust purposes, just giver!
                          I'll get in the garage once this cold snap gets outta here!
                          After I fix this leak I'm heading straight to the dyno.
                            dont fix the leak, then we all wont be able to follow you there.
                              Gift from the girlfriend!!!
                                Please tell me you have a jumpsuit to match the shoes!
                                  Oh God do I wish!!!
                                    In what situation does one wear shoes like that?
                                      When one drives a s52 turbo e30 with gold goodies 😃
                                        If there is a fear of getting lost or when stunting hard is the only remedy for a situation.
                                          Perfect for Wheelies
