  3. BMW Discussion
  4. Supercharger or turbo
27 Posts 9 Posters 414 Views 1 Watching
  • P
    P
    PerryLa79
    I wonder how hard it would be to do it
      With a welder anything is possible!
        SubmuzikBoss said:
        I can't do that for me e90 325 can I?
        Sure thing.
        This is on an E46 325i
        http://forums.bimmerforums.com/forum/showthread.php?1491575-TURBO-PROJECT-E46-325I-10-15-lbs
        • S
          S
          SubmuzikBoss
          That wud be sweet if I cud
            It would definitely be a fun project.
              Are there any power gains from a remote mounted turbo? I can't see any advantage besides space savings and cutting down on engine bay temps. I can see the turbo being more laggy due to being that far down the line.
                It is not as efficient as one mounted closer to the engine with higher pressure + higher velocity exhaust gas, but the advantages I see are not having to buy an exhaust manifold or intercooler (you can say the same thing for a supercharger) and not having to deal with hacking things up in the engine bay to get it to fit. The OE mufflers are quite large so removing that gives a decent amount of space to work with.
                Its not the best way to turbo, but like i said, If you have some money to burn on a car that you will eventually return to stock and sell, then a remote turbo system would be very easily reversible.
                  Its definitely one of the better alternatives I would say.
                  • P
                    P
                    PerryLa79
                    Turbo it is then. Going to get the plans into work.
                      a few example videos I found.
                      • P
                        P
                        PerryLa79
                        Yeah I seen them already. But thanks man
                          What is your budget on this build?
                          • P
                            P
                            PerryLa79
                            I am not quite sure if I am going to do it yet because of being in Wisconsin and my 540i is my daily driver. Don't want snow getting all up in my turbo.
