  3. BMW Discussion
  4. Supercharger or turbo
27 Posts 9 Posters 414 Views 1 Watching
  • P
    P
    PerryLa79
    Yeah I know that turbo is way better and that's what I was thinking
    • P
      P
      PerryLa79
      Snap what is a remote mounted turbo?
        Most superchargers sound like garbage.
        I say remote mount turbo
        I worked on a GTO with a rear mount turbo set up years ago.  Plumbing... Plumbing for days...
        • P
          P
          PerryLa79
          How does it work when it's in back of the car?
            It is a good way to go if you want to go turbo and be able to revert the car back to stock easily.
            -Intercooler not needed
            -uses stock exhaust manifolds
            -keeps excess heat out of the engine bay
            STS makes kits but it wouldn't be difficult to make your own. Their site will give you an idea on what its all about.
            [http://ststurbo.com/
            post-69290-1261357494.jpg](http://ststurbo.com/)
            mmfp080328z%2B2007SEMAconvention%2B
            • P
              P
              PerryLa79
              Snap do you run that?
                Something like this should work...
                • P
                  P
                  PerryLa79
                  I wanna cleaner look
                    Nope, no remote mount here. I used to live near STS though and tons of people in the area ran them.
                    • S
                      S
                      SubmuzikBoss
                      I can't do that for me e90 325 can I?
                      • P
                        P
                        PerryLa79
                        I wonder how hard it would be to do it
                          With a welder anything is possible!
                            Sure thing.
                            This is on an E46 325i
                            http://forums.bimmerforums.com/forum/showthread.php?1491575-TURBO-PROJECT-E46-325I-10-15-lbs
                            • S
                              S
                              SubmuzikBoss
                              That wud be sweet if I cud
                                It would definitely be a fun project.
                                  Are there any power gains from a remote mounted turbo? I can't see any advantage besides space savings and cutting down on engine bay temps. I can see the turbo being more laggy due to being that far down the line.
                                    It is not as efficient as one mounted closer to the engine with higher pressure + higher velocity exhaust gas, but the advantages I see are not having to buy an exhaust manifold or intercooler (you can say the same thing for a supercharger) and not having to deal with hacking things up in the engine bay to get it to fit. The OE mufflers are quite large so removing that gives a decent amount of space to work with.
                                    Its not the best way to turbo, but like i said, If you have some money to burn on a car that you will eventually return to stock and sell, then a remote turbo system would be very easily reversible.
                                      Its definitely one of the better alternatives I would say.
                                      • P
                                        P
                                        PerryLa79
                                        Turbo it is then. Going to get the plans into work.
                                          a few example videos I found.
