  3. BMW Discussion
  4. Supercharger or turbo
27 Posts 9 Posters 414 Views 1 Watching
  • P
    P
    PerryLa79
    How does it work when it's in back of the car?
      It is a good way to go if you want to go turbo and be able to revert the car back to stock easily.
      -Intercooler not needed
      -uses stock exhaust manifolds
      -keeps excess heat out of the engine bay
      STS makes kits but it wouldn't be difficult to make your own. Their site will give you an idea on what its all about.
      [http://ststurbo.com/
      post-69290-1261357494.jpg](http://ststurbo.com/)
      mmfp080328z%2B2007SEMAconvention%2B
      • P
        P
        PerryLa79
        Snap do you run that?
          Something like this should work...
          • P
            P
            PerryLa79
            I wanna cleaner look
              Nope, no remote mount here. I used to live near STS though and tons of people in the area ran them.
              • S
                S
                SubmuzikBoss
                I can't do that for me e90 325 can I?
                • P
                  P
                  PerryLa79
                  I wonder how hard it would be to do it
                    With a welder anything is possible!
                      Sure thing.
                      This is on an E46 325i
                      http://forums.bimmerforums.com/forum/showthread.php?1491575-TURBO-PROJECT-E46-325I-10-15-lbs
                      • S
                        S
                        SubmuzikBoss
                        That wud be sweet if I cud
                          It would definitely be a fun project.
                            Are there any power gains from a remote mounted turbo? I can't see any advantage besides space savings and cutting down on engine bay temps. I can see the turbo being more laggy due to being that far down the line.
                              It is not as efficient as one mounted closer to the engine with higher pressure + higher velocity exhaust gas, but the advantages I see are not having to buy an exhaust manifold or intercooler (you can say the same thing for a supercharger) and not having to deal with hacking things up in the engine bay to get it to fit. The OE mufflers are quite large so removing that gives a decent amount of space to work with.
                              Its not the best way to turbo, but like i said, If you have some money to burn on a car that you will eventually return to stock and sell, then a remote turbo system would be very easily reversible.
                                Its definitely one of the better alternatives I would say.
                                • P
                                  P
                                  PerryLa79
                                  Turbo it is then. Going to get the plans into work.
                                    a few example videos I found.
                                    • P
                                      P
                                      PerryLa79
                                      Yeah I seen them already. But thanks man
                                        What is your budget on this build?
                                        • P
                                          P
                                          PerryLa79
                                          I am not quite sure if I am going to do it yet because of being in Wisconsin and my 540i is my daily driver. Don't want snow getting all up in my turbo.
