  • 240sxguy2
    240sxguy2
    240sxguy
    I had no idea you could get epoxy primer in a rattle can. That's good to know. Cool car!
    • The Full BananaT
      The Full BananaT
      The Full Banana
      Just realized I haven't update this in a while. Here's a slew of pictures.
      The bay.
      Front control arms boxed, painted and undercoated.
      17x8 BBS RC (<17lbs each)
      Masking for paint after a lot of prep time.
      Block freshly painted.
      Flocked dash installed along with alllllllll the wiring and heater control stuff.
      More stuff tossed in.
      Someday, it'll be a real car. At least it has front suspension bolted up now.
      Unintentionally blinged-up alternator.
      Getrag 265 swap parts: Bellhousing adapter plate, centering ring, shifter cage and linkage to fit 240 shifter location, driveshaft support bearing relocation bracket.
      Getting more things together. Meticulously prepped the exhaust manifold and turbine housing, then painted them with 'Stove-Brite' (Old man trick for good HIGH heat paint. Volvo guys use this on turbine housings and say it holds up remarkably well. One guy has been using it for 30 years...)
      Phenolic intake manifold spacers to help abate some amount of heat transfer when I'm asking for all that the little baby TD04HL-16T turbo is worth.
        Everything looks great!
          So awesome, love the build!
            VERY nice!
              Sweet deal man! Nice work!
                I was just wondering what had happened with this car recently!  I love the old volvos!  Nice build!
                  Looks like you are doing all the right things Tom. Keep it up=)
                  • The Full BananaT
                    The Full BananaT
                    The Full Banana
                    Thanks guys! It's been a lot of fun so far, and there are more neat things on the horizon. Cayenne 6-pots are spendy...
                      Flocked the dash?  Can we get some more pics?  I've been thinking, nay musing, about it recently.
                      • The Full BananaT
                        The Full BananaT
                        The Full Banana
                        I'll see if I can get a decent picture next time I'm in the garage.
                          Wow, this is coming a long way! What color is the bay sprayed?
                            I like dis
                            • The Full BananaT
                              The Full BananaT
                              The Full Banana
                              It's Duplicolor Engine Enamel 'Cast Coat Iron' with a whole bunch of clear and wax on top.
                              It's a really goofy color. Looks a lot different depending on the lighting. In natural light it's a dark grey, and incandescent light brings out a lot more greenish brown. Certainly different, but I like it. I wanted some amount of contrast with the exterior paint while still being somewhat neutral.
                                That's what my block is painted with. Great choice. When are you planning to throw the motor in?
                                • The Full BananaT
                                  The Full BananaT
                                  The Full Banana
                                  Hoping to drop it in next weekend. I just need to clean and paint a few brackets.
                                  • The Full BananaT
                                    The Full BananaT
                                    The Full Banana
                                    Quick couple things: (the other things I don't have pictures of yet)
                                    Tossed on the new 330mm rotors (Volvo S60R) and threw a RC over top to get an idea.
                                    modified Volvo bellhousing with adapter plate to mate to my getrag 265
                                    Engine complete-enough to go in.
                                      Looking good!
                                        Dat in-jun doe.
                                          I thought you were going to drop the engine in a few weekends ago? =P
