    Tom are you going to swap the motor out of the wagon into the coupe?
    • The Full BananaT
      The Full BananaT
      The Full Banana
      Bassboy3313 said:
      Wow! Looks like one hell of a project. Definitely keep us updated on this one. Looking good so far!
      I'll drop pictures in here from time to time, but here is the dedicated project thread on the volvo forum: http://forums.turbobricks.com/showthread.php?t=284730
      Yep! It'll get pretty much everything from the wagon. In a couple years I'd really like to put a worked over m50/52 in it and cram some air in it. Volvo redblocks are pretty capable little tractor motors that can provide a lot of fun at minimal expense, but I really love pretty much everything about the bmw inline 6s.
      Here are a few pictures:
        The Full Banana said:
        Stock removable core support? Jelly! I need to design one for the front end damage prone E28s  :mellow:
        • The Full BananaT
          The Full BananaT
          The Full Banana
          Yep! Some of the different years have a few spot welds to drill out, but on this car I just unbolted everything.
          More pictures. 50ft2 roll of Fat Mat Rattle Trap, and 100ft2 roll of Mass Loaded Vinyl showed up.
          Got started on the passenger door.
            Great progress Tom=)
            • The Full BananaT
              The Full BananaT
              The Full Banana
              More progress this weekend. Copied and pasted from my project thread.
              Measured and cut out the strut tower opening to make room for camber plate adjustment.
              Finally wrapped up the prep and sprayed the engine bay with Spray Max 2K epoxy primer. For an aerosol can, this stuff is pretty great.
              Then I pulled the dash out of the wagon. This is in way worse condition than I realized. Not sure what I'll end up doing with this.
              I'll be using some of the blue interior trim from the wagon for this car, so I tried out Duplicolor interior paint. Seems to be pretty good.
              • The Full BananaT
                The Full BananaT
                The Full Banana
                Been working quite a bit on this, but not much to show for it.
                The engine bay is finally done, save for a little wax.
                Steering rack cleaned up
                Dash stuff. I repaired the dash cover; just need to refinish it now.
                • 240sxguy2
                  240sxguy2
                  240sxguy
                  I had no idea you could get epoxy primer in a rattle can. That's good to know. Cool car!
                  • The Full BananaT
                    The Full BananaT
                    The Full Banana
                    Just realized I haven't update this in a while. Here's a slew of pictures.
                    The bay.
                    Front control arms boxed, painted and undercoated.
                    17x8 BBS RC (<17lbs each)
                    Masking for paint after a lot of prep time.
                    Block freshly painted.
                    Flocked dash installed along with alllllllll the wiring and heater control stuff.
                    More stuff tossed in.
                    Someday, it'll be a real car. At least it has front suspension bolted up now.
                    Unintentionally blinged-up alternator.
                    Getrag 265 swap parts: Bellhousing adapter plate, centering ring, shifter cage and linkage to fit 240 shifter location, driveshaft support bearing relocation bracket.
                    Getting more things together. Meticulously prepped the exhaust manifold and turbine housing, then painted them with 'Stove-Brite' (Old man trick for good HIGH heat paint. Volvo guys use this on turbine housings and say it holds up remarkably well. One guy has been using it for 30 years...)
                    Phenolic intake manifold spacers to help abate some amount of heat transfer when I'm asking for all that the little baby TD04HL-16T turbo is worth.
                      Everything looks great!
                        So awesome, love the build!
                          VERY nice!
                            Sweet deal man! Nice work!
                              I was just wondering what had happened with this car recently!  I love the old volvos!  Nice build!
                                Looks like you are doing all the right things Tom. Keep it up=)
                                • The Full BananaT
                                  The Full BananaT
                                  The Full Banana
                                  Thanks guys! It's been a lot of fun so far, and there are more neat things on the horizon. Cayenne 6-pots are spendy...
                                    Flocked the dash?  Can we get some more pics?  I've been thinking, nay musing, about it recently.
                                    • The Full BananaT
                                      The Full BananaT
                                      The Full Banana
                                      I'll see if I can get a decent picture next time I'm in the garage.
                                        Wow, this is coming a long way! What color is the bay sprayed?
                                          I like dis
