    Maybe you should follow them to the ti...
      I see what you did there ^^
        I got the oil filter bolt modified today.
        To me it looked terrible with it being the only non stainless socket head bolt. After thinking of a few ways to do it, this seemed the easiest and made the most sense.
        The head of the bolt was faced off and a hole was drilled down the center. We then tapped the hole to 5/16-18. The socket head bolt threads in, acting as a new head.
        The black oxidized bolt is just for mock-up. I have a 5/16-18x3/8" stainless bolt on order. Once it arrives I will use a strong thread sealant to essentially make the bolt one solid piece.
          Any one close by that could tig weld it for him?  Put it all together, weld the SHCS to the washer and the washer to the bolt, then put it back in the lathe and turn it.  Then it would be all one, and look Earl fancy.
            The thing is that the original bolt is steel and the new bolt stainless. Since it is only two pieces and doesnt get tightened crazy tight I can just use a really heavy duty sealant=)
              You can weld that no problem, I have tig welded mild to stainless and it turns out great.  I'm not saying the sealant wouldn't work, it would just be "because fancy."
                That would suck if there was an oops moment and the sealant broke loose.
                  I would just put new sealant in, let it dry, and then back it out=)
                    I got out to the shop yesterday. It felt great to be back at it.
                    I started off by fitting the latest batch of stainless hardware. All of them fit great except for one of the alternator bracket bolts. The one that they gave me is way too short=/ I will be ordering it when I pick up my oil filter housing bolt today or tomorrow. I didn't get any pictures because my engine is in a dark corner.
                    I also test fit the modified oil filter housing bolt with the temporary head.
                    It will fit right in when the stainless bolt is there and sealed in.
                    After I got all of those in I decided to mount my trans bushings for now.
                    While I was doing all of this myself, my friend Greaser Kyle was in the bay. He started by patching the indent behind the drivers side tower.
                    There are these indents on the inside of the strut towers.
                    Originally I had planned to use black plastic plugs in the holes to clean them up, but Kyle was in a patching mood.
                    He then filled in the seam along the bottom of the tower.
                    Since that patch went so well, Kyle wants to patch a lot of indents that I was just going to leave alone. He is the artist here and it will lead to a much cleaner look. That is completely fine by me=)
                    I will be back at it this weekend. Hopefully I will have a good update
                      You are fortunate to have a friend with good welding skills
                      Reward that man with an ice cold Doc360.
                        I am very fortunate=) If he likes Doc360 I will be sure to give him one
                          Usually welders want women.  Thats why I'm not so quick to hire them.  Might want to prep the GF.
                            Looking good - spring is gonna be here fast!
                              hahahahaha He is a good friend. Hopefully he wouldn't try and pull that=P
                              I know=( Being one handed really kills productivity.
                                Since I am going through the trouble of making almost everything new, I am going to tackles front hubs.
                                I have been looking around to see what's available and have seen a few interesting things.
                                The cheaper ones use a rougher casting that requires less machining. I am unsure of the bearing quality, but I am sure they aren't as well made as the more expensive ones.
                                I am stuck between these two on ECS Tuning:
                                http://www.ecstuning.com/ES2091579/
                                http://www.ecstuning.com/ES10373/
                                The top one is an example of the cheaper casting, but I am unsure of how well it does the job.
                                I am thinking I should play it safe and buy the more expensive SKF assembly. The thing that gets me is the $80 price difference for a pair. Are the SKF assemblies going to outlast and out perform the MTC assemblies enough to justify higher price tag.
                                  what exactly needs to be machined.
                                    I never cheap out on bearings, especially on something that might see -69 degrees of camber.
                                    You CAN however, find quality bearings for a decent price if you look hard enough.
                                    but,
                                    YOLO and you may have good luck with the MTC stuff so this whole post is pointless.
                                      Nothing. I am just talking about how they were manufactured. You can tell by the back of the hub.
                                      but,
                                      My thoughts exactly. haha I may get the SKF just for the peace of mind=)
                                        Just ordered my rotors from Adams Rotors. I cannot wait to see the quality and I hope they last a long time.
                                        I need to pull together another parts list to combine with the front hub order. I will take care of that this weekend. I cannot wait to have both hands again=)
                                          I'm sure those rotors will last forever on a car that never leaves the garage :P
