  3. Services Offered/Wanted
  4. Legit Painters around here?
snap likes raw
33 Posts 10 Posters 589 Views 1 Watching
  • M318M
    M318M
    M318
    In fact, plasti dip is quite brilliant being cost-effective and all. It allows you to try out different colors without the risk of ruining what you have already. It protects surfaces from chipping, fading, scratching and corrosion. Why would you knock such an innovative product? Is it because of the "fad" element?
      Plasti-dip isn't exactly my cup of tea. I used it on my wheels, looked, OKAY at best. An just all around wasn't impressed. Oh well, to each there own
        you just dont like it because you can't huff it.
        • Ryan...R
          Ryan...R
          Ryan...
          Honestly, might not even bother with all the little nooks and corners like the inner trunk area. It's got over 200k, and it will be lucky to outlive even the crappiest of paint.
            Removing plastidip blow and for the $300 you spend on it it isn't worth it for a solution like this. I highly recommend you researching the $50 rustoleum paint jobs. They turn out amazing for what they are.
              HOLY  ****  I just noticed the thread tag
              • Ryan...R
                Ryan...R
                Ryan...
                Oh snap u so silly¡
                Earl, I'm all for cheap, but I really wanna learn to lay some hella legit paint.
                  It is legit=)
                  http://www.rickwrench.com/index79master.htm?http://www.rickwrench.com/50dollarpaint.html
                  • Ryan...R
                    Ryan...R
                    Ryan...
                    (°_°)
                      Was going to do it to my MK3 but then got rid of it=)
                      • H
                        H
                        Hammerdown
                        Interlux polyurethane marine paint.  Spray it on with a HVLP gun and can get two coats from a $50 quart can.  It is a gloss finish though.
                        • 240sxguy2
                          240sxguy2
                          240sxguy
                          What I don't understand is why you'd do a "$50 paint job" with rustoleum and not just get a legitimate single stage catalyzed paint instead. It's not a huge price difference. What, 150 or 200 in materials tops? Working with catalyzed paint takes the mystery out of the drying/cure time. Oh, and Ryan. If you really want the real experience of painting a car, do it all and do it all right. It's the best practice you'll ever get.
                          • H
                            H
                            Hammerdown
                            Interlux is far superior to Rustoleum. It is a topside and hull paint made to stand up to weather. I've done the Rustoleum on a car and it doesn't last but a year before fading. I've done Interlux on a whole car and on sailboats and it works fine.
                            If Ryan doesnt want to stick a lot of $ in the Boobaru it is an acceptable way to go.
                            • 240sxguy2
                              240sxguy2
                              240sxguy
                              I am familiar with Interlux, and I know it's a totally different paint. I was posting in reference to the post above yours, but you snuck one in while I was typing.
                              • Ryan...R
                                Ryan...R
                                Ryan...
                                Yeah I would like to do it the legit way. I have access to a good spray gun from my uncle and any other painting tools I may need.
                                I'm going to be filling/shaving the side markers and debadging the trunk before painting. I'm excited to do it, but I'm not going to go full on removing the glass etc... probably use plasti dip in the door jams and interior trunk bits if I dont feel like doing the prep work in those tight spaces.
